 Location: Home of the WNFR at Christmas | We just ringed our little pasture, about an acre, with trees and to keep the horses from thinking they are snacks we put up a two strand hot poly-rope fence.
We seem to be having some grounding problems to get a good jolt out of it, any one that has used this type of fencing got any tips ?
Right now it is set up as the top rope is hot, the lower is ground and then a ground into a rod in the earth, that seemed to be the only way to get a decent jolt.
Just to add to the fun we live in the dry hot desert outside of Las Vegas.
Thanks |
      Location: La Cygne, KS | This may sound silly, but have you watered the earth/rocks where your ground rod is? We've poured water on the ground to get a good charge on the portable fence when we traveled to rocky areas. That seemed to do the trick. You might have to add some good dirt to get a zippy charge. Also, is your charger solar or electric? If Solar, it takes awhile to get the battery fully charged to get a good zap. |
 Location: Home of the WNFR at Christmas | I did water the ground rod, actually moved it to a treewell earlier today, that is watered 2 times daily. I am using a plug in charger so that should not be the issue. |
      Location: Texas | That's a common problem in dry soil. One solution is, instead of having all your strands hot, make one of them a ground strand. Ground it to the ground rod and charger. Then, when a horse touches a hot strand and the ground strand, the conductivity of the soil does not matter. |
  Location: Alberta | You may have to use copper bonded and/or multiple ground rods to get a proper ground. You can join 2 rods getting down to hopefully a better ground, or multiple single units connect by copper wire.Before you go to all this trouble, you may want to test your fencer with a known good ground. |
