Coleman Hot Water on Demand
Rockinghorserun
Posted 2009-04-26 9:44 PM (#103992)
Subject: Coleman Hot Water on Demand
I have a Coleman HWD that doesn't charge the battery up anymore. Does anyone know how to work on these or if there is something I can do myself to fix this?  They won't work unless the battery is fully charged.
Terri
Posted 2009-04-27 2:54 AM (#104001 - in reply to #103992)
Subject: RE: Coleman Hot Water on Demand
200050010010010025
You will probably need to buy a new battery.
Rockinghorserun
Posted 2009-04-27 7:41 AM (#104009 - in reply to #103992)
I did replace the battery and it ran 2 times. The low battery light came on and I plugged it in. The recharging light was on but when I unplug it the green light does not come on and the battery is not charged.
gemm
Reg. Feb 2005
Posted 2009-05-01 11:57 AM (#104274 - in reply to #103992)
100100100100252525
You might want to check the connections, as well as if the battery is fully charging. Mine takes a long time to re-charge...like 24hrs or so. Good luck. We get spoiled with our hot water, don't we?
