Location: pacific northwest | I have spent *(&^%%# hours searching for replacement panels for my horse trailer I just inherited. I can't find a &&*& place at all!!!
Where are they? I need a new nose and I want to replace the roof. It is a steel 2 horse bp 1970 ish Thanks! Cam |
Location: pacific northwest | I want to replace the roof. I need to replace the front nose cone. Thank you but I have been to all those sights and nothing I am looking for. I need to know where to get the replacement panels that gard mentioned as well as the nose fronts. Thanks, Cam |
      Location: Rocky Mount N.C. | Sounds like you need to take it to a local auto body shop/metal fabrication company. Have them cut out the old tin, shape and install the new stuff. Count your money before you start doing alot of refurbishing to an old trailer.... Most of the time it's alot cheaper and easier to go out and buy a clean used unit..... Replacing the nose and roof is going to run the bill way up. What make trailer is it? |
Location: pacific northwest | Not the advice I am looking for reto. Money is not an issue. I am training the horse myself, I want to overhaul the trailer myself. I just built a 30 x 40 shop that my trailer is dying to get re-done in. Can anyone else point me in the direction of replacement parts for a horse trailer? And a helpful website? I am looking to replace the nose, I want t o replace the roof, ass diamond plating and possibly go to a ramp as well as a step up (as it is now) Thanks! Cam |
       Location: western PA | I assume that the reason you are willing to spend more time and money on this project than its worth, is personal reasons due to your inheritance. I'm sure you're aware of your trailer's value now and when it's completed. To replace a roof is a major undertaking, because few of the pieces are continuously flat. The nose cap is the most difficult to replicate because of the involved compound curves. Few manufacturers had the funds to purchase the stamping equipment, that could form the part from one piece of metal. Most were built of several pie shaped pieces, individually bent over a form and welded together. Many manufacturers had a different radius or shape for the front of a trailer, and different profiles for the height. I might suggest against a complete roof replacement, and instead, recommend repairing just the damaged areas. Cutting out the poor areas and welding in new steel will be more manageable. You will need some good welding and cutting equipment and skills to effect these repairs. To replace and replicate curved panels, you will have need of a commercial fabrication shop with heavy sheet metal tooling. This will include a brake, shear, roller , plasma cutter, and probably an English Wheel. "Panels" can be a piece of metal a foot square or the whole side of a trailer. I have not suggested that there is a source of ready made parts available for trailer repairs. I have often said that panels can be fabricated as needed. We are not arguing against your wish to renovate your trailer. We just want you to be aware that it is not cost effective. Once you have made the decision to press on regardless, I admire you for your dedication to preservation values. Your time is not free, it is the most expensive commodity you have and it's finite. To exchange many hours of work for a finished restoration, is very rewarding. I wish you the best. Gard
Edited by gard 2009-04-27 5:31 AM
