I have an older Sooner trailer that I'm replacing all of the marker lights on.
The lights are M2 series 3.75 X 1.2 with 2 pin snap in mounting.
I just tried a light from super brite led's and it works.
Their's have 12 LED's in the center but none on the ends.
My original lights have 1 bulb on each end.
Just out of curiosity, are there any replacement LED's with the lights on the ends as well? (with that 2 pin mounting system)
- Dave
      Location: Decatur, Texas | Can u post a picture so we will know for sure what light you have? I have had 2 older Sooner trailer and the 04 had the truck lite 19 series lights which sounds like what you are talking about and no, the led's are only in the center section. However at night when turned on with the LED'S it looks like the entire lens is glowing and WAY brighter than the standard lights.
If you are talking about the series 19, the new style CLEAR LENS with the amber or red lights look really good on any trailer. We are replacing the ones on our Sundowner this weekend. |
Location: Pittsburgh, PA | I have the M2-R12 pictured on top with the 2 pins.
http://www.superbrightleds.com/specs/m2.htm
      Location: Decatur, Texas | Yes, those are the same lights as the series 19 truck lites! Check out the clear lens LED, they look sharp! |
I think you mean this one?
http://cgi.ebay.com/ebaymotors/Maxxima--Marker-LED-light-Amber-Clea...
    Location: Florida | I just received my new 6 inch LED ovals to replace my tail and back ups.I am hoping to install them this weekend.I like the marker lights, didn't even think about those. If these work out to plan I will probally be replacing the markers next.Thanks for the links.Brighter is better. |
Location: Pittsburgh, PA | I installed the one I got in the middle of the 3 front marker lights. It was ok, but just didn't seem as bright as other LEDS that I've seen.
I did look at the case and thought it looked REALLY deep yellow compared to my original lights, but then kind of let it go.
I just ordered one of the clear ones to check it out.
I go one at a time to make sure I get it right instead of ordering all 22 and screwing up. LOL
- Dave
      Location: Decatur, Texas | YES, That is the ones. I think I got mine from a dealer in FL.... I called him direct and he cut me a better deal on buying more at one time and saved money on shipping too. I put them on a 2007 S&H 3 horse gooseneck we had, and now working on replacing the regular LED's our Sundowner has with the clear lens LED's. Should look good since our trailer has the painted top rail and corner post. |
