Location: RICHMOND, MO | has anyone had problems with these tires blowing out? |
      Location: Decatur, Texas | Not any more! I bought Goodyear G614'S and solved my porblems. But they are actually a little wider than the origianl tires. |
Location: RICHMOND, MO | Yea but Im trying to get as many people as possible that had problems. This is rediculous that sundowner has not done anything about this and we all have to put new tires on a trailer. Especially mine was brand new trailer when bought. |
      Location: Decatur, Texas | Originally written by I HOOF IT on 2009-03-24 1:09 PM
Yea but Im trying to get as many people as possible that had problems. This is rediculous that sundowner has not done anything about this and we all have to put new tires on a trailer. Especially mine was brand new trailer when bought. How old is your trailer? Sorry to say but the tire deal is like beating a dead horse. |
Location: RICHMOND, MO | our trailer is now 3 years old and I have talked to them before about this. And if nothing else, they will remember me when I get done this time!!! |
      Location: Rocky Mount N.C. | I seen a new trailer several weeks ago, (a 2006 model), brand new that had never been sold. It was a 4 horse, big lq, three 7000# axles, with six of the worse cracked Uniroyal Laredo AWP's you've ever seen..... I looked at the tires and they were three years old. Trailer has only sat on the lot and gets pulled to a show now and then for display. They will clean up the trailer and these tires get greased with this tire dressing crap that's full of alcohol..... Know what alcohol does to a tire sitting on the ground, in the sunlight? Sidewall cracks you could stick a quarter in. The only thing is, the Chinese tires don't need the help of the alcohol, they will unravel all by themselves. Good luck, but your best bet is to buy a set of Goodyear G614's if you need something that stout, or a set of Michelin XPS Rib's or even a Goodyear Marathon. The Marithon is built in China but it meets Goodyears U.S. standards, it has the UV protection. Some info from other sites as well as HTW about Trail America Tires as well as others. http://www.heartlandowners.org/forum/showthread.php?t=3340 http://forums.iboats.com/showthread.php?t=189875 http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=10956 http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=9319 http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=9193 Good luck.... |
| Tire issues are always a headache!!!! With every brand of trailer. I think it's a conspiracy... |
Location: RICHMOND, MO | well this is what we have found out about our tires that are on our trailer. The tires on your unit are Trail America 235/85R16 LOAD RANGE G. Your Sundowner trailer most likely has a GVWR of 18,000lbs. The load range G carries a maximum load is 3750lbs(3750x4=15,000lbs) That is 3,000lbs less than the GVWR. Using a Trail America Tire Wheel assembly that does not have an adequete load rating to support the listed GVWR is not recommended and will void any and all warranties. Also, due to the many ways weight can be distributed on a trailer, JCA Corporation/Trail America does NOT allow for tongue weight reduction. so Sundowner is at fault here. |
 Location: Broomfield, CO | I had trail america tires, and they all blew out! 3 blowouts 200 miles apart in one trip!! I always carry 3 spares! Messed up the fenders on my trailer too. Major damage!!! My Used Elite came with these tires. All of the wear was even, they looked brand new. I bought all new tires, but still can not afford to fix the fenders! I made the tire shop destroy the 2 remaining trail america tires in front of me so the couldnt be resold! |
| Originally written by I HOOF IT on 2009-03-25 4:17 PM
Well this is about asinine. Trail America cannot expect a manufacturer to operate like this. If Sundowner had put bigger tires on it, then they'd need bigger axles- AND THEN THE GVWR WOULD GO UP AGAIN- What a Catch-22!! In this range trailer, the GVWR ratings have to be fairly accurate. As you approach 26,000# GVWR the IRS "frowns" on down rating the numbers. Sounds like a Trail America cop-out to me. I won't usually defend many trailer mfg., but this isn't Sundowner's fault.
     Location: Where the wind comes sweepin' down the plain... | Originally written by horsey1 on 2009-03-26 7:57 AM Well this is about asinine. Trail America cannot expect a manufacturer to operate like this. If Sundowner had put bigger tires on it, then they'd need bigger axles- AND THEN THE GVWR WOULD GO UP AGAIN- What a Catch-22!! In this range trailer, the GVWR ratings have to be fairly accurate. As you approach 26,000# GVWR the IRS "frowns" on down rating the numbers. Sounds like a Trail America cop-out to me. I won't usually defend many trailer mfg., but this isn't Sundowner's fault. Agree 100% with this. The other option Sundowner would have had would be to assign a GVWR for the trailer that is a total of the axles or tires, then when the trailer as a whole is overloaded they would have been to blame. This is the whole reason for a GAWR on the VIN plate. |
      Location: Rocky Mount N.C. | (quote I HOOF IT) The load range G carries a maximum load is 3750lbs(3750x4=15,000lbs) That is 3,000lbs less than the GVWR. I would think that extra 3000+# would be on the pin in the bed of the truck. What's the individual axle ratings... 8000# My S.W.A.G. is, you got 16000# of axles, 15000# of tire, 20% of the trailers GVWR in the bed is 3600#.... 18000# GVWR minus 3600# on the pin equals 14400# on the trailer axles.... So you are good, you're maxed out, but you're good to go. You just got a sorry set of tires. Be sure you're running level and none of those turns where one side of the trailer is trying to back up while you are going forward... That will tear up the best of tire, maybe not at that moment, but run it hard, loaded heavy, in hot weather and you'll find out how bad they were damaged. One other thing, some of those Chinese built "trailer tires" are speed rated to 65 mph.... Anything much above that when loaded, they will start to disintegrate in a hurry, cords breaking, chunks flying off, exploding, etc... Most all of the "ST" tires are speed rated to 65 mph. Good tires ain't cheap, cheap tires ain't good and if they are 5 to 6 years old, it's time to replace them. My thought is, if Sundowner is at fault for anything, it because they used the CHEAP tire.... approx. $100.00 a piece, for the Trail American -vs- $300.00 for a G614RST tire.... Do that five times for one trailer (4 on the ground plus the spare) and that's a savings to SD of.... $1000.00 for that one trailer!!!! I wouldn't have ever bought the trailer with the Trail America tires, but that's just me. Next thing for you to do is load everything up and roll it across the scales, that's the only way you'll know for sure that you are correct. What does each truck and trailer axle weigh when loaded??? |
Location: Ontario | I just blew 3 of these tyres in three separate events within 4 days of each other on a trip from Ontario to North Carolina. Major damage to both sides of my trailer. Less than 20,000 km on the Sundowner and 3 years old as of the day of the second blowout. Hubby is a truckdriver and checks his tyres every time we stop - put air in before we left, had them checked again after the first blowout and again before we headed home. Has anyone considered a class action suit? How many people have been killed or seriously injured as a result of these blowouts??? |
    Location: MO in woods | Oh Yes we had blow out on secod short distance time pulled trailer.We pulled trailer over to friends to haul weanling and had blow out while had nothing in trailer.....Than again few months later another blow out.Husband knows I drive like old lady while pulling horses so called dealership and they did replace one tire.Stems in proper place was reply from body shop and crap ass No quality tires in first place too JMHO and many orther peeps too. |
Location: Ontario | Has anyone been successful in pursuing Trail America or Sundowner for the cost of replacement tires or for damage to their trailer resulting from the blowouts? |
    Location: Iowa | Originally written by retento on 2009-03-26 8:41 AM ( Good tires ain't cheap, cheap tires ain't good and if they are 5 to 6 years old, it's time to replace them. Ok, So here's one for ya.. I have a 2003 featherlite 3H Slant. Don't pull it alot, but enough. The rest of the time it sits in the barn. On concrete. The tires are in excellent condition, or so they seem. Should I toss them then? I should add..They are the original tires. Edited by sinful 2009-08-17 5:33 PM
   Location: MI. | Our 2006 is getting changed out before it goes on the road next spring. We needed truck tires first. We don't haul anymore than 3-4 hours at a time. I just don't trust the tires.
Edited by Gone 2009-08-17 3:57 PM
Location: Oklahoma | Do you think that air pressure may be a culprit here? I agree that Trail America's are a crappy tire, but, any tire can blow if you don't have it properly inflated. I don't care who makes it. It is hot everywhere this time of year and if you don't have your tires properly inflated, it will cause the tire to run "hot" and it WILL blow. |
        Location: Vermont | Originally written by I HOOF IT on 2009-03-24 3:01 PM
our trailer is now 3 years old and I have talked to them before about this. And if nothing else, they will remember me when I get done this time!!! BUT...HOW OLD ARE THE TIRES? Check the DOT code...you may be unpleasantly surprised... |
Location: Ontario | We checked the air before the first blowout, after that and before the 2nd and 3rd blowouts, and both service centres said the tires looked good - no cupping, no cracks, very little wear. And there was no loss of rubber first, the tread completely separated and the tire EXPLODED in an instant. |
       Location: western PA | Originally written by civey on 2009-08-17 1:20 PM
Has anyone been successful in pursuing Trail America or Sundowner for the cost of replacement tires or for damage to their trailer resulting from the blowouts? I sued Firestone after one of their tires failed and almost killed my whole family. My attorney wisely would not take the case on a contingency basis, wanted $3k to start, and I finally got him down to billable hours @ $275/ per. The Firestone dealer that inspected the tire remains, said the blowout was definitely caused by a carcass failure which resulted in a thread separation. Without seeing the tire, Firestone Inc denied any wrong doing, and refused any compensation. After several refused demand letters and corporate run around, I stopped throwing good money after bad; the exact response Firestone expected. The problem was, according to my attorney, is that a death did not occur. Because my physical damages amounted to aprox $2300, it would cost more than that to pursue the case. Had a fatality occurred, the higher liability would have made the case worth pursuing. It is very difficult for one person to sue corporate america because of the financial difficulties. Their litigation cost are figured as part of the cost of doing business, and are budgeted on a yearly basis. The only people that win in a class action suit are the attorneys. The litigants usually see very little, individual compensation. BOL Gard
Edited by gard 2009-08-18 9:27 AM
Location: Ontario | Good feedback, thank you. I did keep one of the blown tires, plus the one that did not yet blow as well as the spare, so can have them all examined, but as you say, the cost is going to be prohibitive. Still hoping someone has had some success or has an idea... |
     Location: Where the wind comes sweepin' down the plain... | Originally written by gard on 2009-08-18 9:09 AM Originally written by civey on 2009-08-17 1:20 PM
Has anyone been successful in pursuing Trail America or Sundowner for the cost of replacement tires or for damage to their trailer resulting from the blowouts? I sued Firestone after one of their tires failed and almost killed my whole family. My attorney wisely would not take the case on a contingency basis, wanted $3k to start, and I finally got him down to billable hours @ $275/ per. The Firestone dealer that inspected the tire remains, said the blowout was definitely caused by a carcass failure which resulted in a thread separation. Without seeing the tire, Firestone Inc denied any wrong doing, and refused any compensation. After several refused demand letters and corporate run around, I stopped throwing good money after bad; the exact response Firestone expected. The problem was, according to my attorney, is that a death did not occur. Because my physical damages amounted to aprox $2300, it would cost more than that to pursue the case. Had a fatality occurred, the higher liability would have made the case worth pursuing. It is very difficult for one person to sue corporate america because of the financial difficulties. Their litigation cost are figured as part of the cost of doing business, and are budgeted on a yearly basis. The only people that win in a class action suit are the attorneys. The litigants usually see very little, individual compensation. BOL Gard Curiosity question Gard - Is there a reason you did not attempt anything with Ford on the issue? If I am remembering right, Ford was specifying a lower psi for the tires than what Firestone recommended... |
       Location: western PA | This involved a Firestone Steelex that was recalled when installed on Excursions, but not SD trucks. It was not part of the mass recall, for the lighter duty passenger duty tires that were problematic in the SUV debacles. |
  Location: rapid city sd | the trailer america tire was defective and sundowner had to replace side sheets on a couple of dozen trailers that I saw come through until they excluded tires in the 3 year bumper to hitch. The side wall would fail and the tread would beat the trailer to death |
| yep, just replaced all four of mine last week!!! tires had less than 7500 miles on them, always at the correct pressure, stored inside, no winter hauling, no salt, washed everytime after use. tire guy said he had never seen anything like it, he stated that the tires should of easly lasted many more miles. |
| Gard, I too had the Firestone steeltex tires on my F-350 they started to seperate and it felt like the front end was coming out from under the truck, changed them both for michelins while hauling away from home got home and talked to the firestone tire dealer and they said they would have to have the tires on the truck to honor any warrenty, I told them by all means you put them on the truck and drive it and please take out extra life insurance and besure your insurance covers my truck! Long story short I got nothing but also have never ever ever bought firestone tires again on any of our fleet of 5 vehicles or three trailers. Also my horse trainer and his horse trainer son who hauled my trailer will not buy firestones, so who ended up the loser? Pat Moore |
       Location: western PA | Originally written by Pmoore on 2009-08-26 8:05 AM Gard, I too had the Firestone steeltex tires on my F-350 and talked to the firestone tire dealer and they said they would have to have the tires on the truck to honor any warrenty, After I had my truck repaired, I drove it to the dealer with the spare on the front and the blow out in the bed. The dealer wanted to replace all of them, but after a call to Firestone Inc, they refused, and the dealer couldn't swap them out. From that same dealer, I then purchased a set of Goodrich tires. (One of my favourite brands) Long story short I got nothing but also have never ever ever bought firestone tires again on any of our fleet of 5 vehicles or three trailers. I'm definitely boycotting Firestone and will tell anyone who will listen about my experience. Also my horse trainer and his horse trainer son who hauled my trailer will not buy firestones, so who ended up the loser? We did |
Location: Ontario | Make sure you also boycott anything that says Trail America on it too.... |
Location: newton, nc | I have a Cimarron trailer with those cheap tires, Trail America, we also had 2 blowouts this weekend alone. So far 4 out of the 5 tires have blown with less than 5,000 miles. It is a crying shame. The dealership we bought our trailer at, asked us if we had bought the tire warranty at the time of purchase. They should of crammed it down our throats, and told us that the tires were cheap, made in China and would not last long, do damage to our fenders when they fly apart in less than an 100 miles on a cool day going up and less than 25 miles on the way home. As much money as all of our trailer cost us, not including the precious cargo we are carrying, trailer manufactures, and dealers should put top notch tires on all trailers. |
Location: Malcolm, NE | Trail America tires also came on our 2005 Titan 4-horse. Totally agree that they are junk. The first blowout was 3 months after we purchased the trailer, 2nd was less than a year, blah, blah, you get the story. Sounds like Trail America made a killing with multiple trailer companies though. |
      Location: La Cygne, KS | Trail America also came on 2005 Elite second half of the year. First 2005 Elite from the beginning of the year had Michelins. Still got the TAs on the trailer.... been showing my husband this post to convince him that we need to change them out before our fall riding trips. |
Location: newton, nc | The Cimarron Factory said we could call Trail America and have had all of the tires replaced, I told him NO WAY. They are suppose to give us Good Year replacements at their cost, on 3 tires since we already have one tire. I would rather have a discount on good tires than the same pieces of c+#p that I had. |
Location: Ontario | Is there not a government consumer protection agency that would look into this as it seems pretty widespread and these blowouts could be life threatening, not to mention the cost of the trailer damage when you figure how many people are affected. Maybe one of the equine media channels would do a story on it? |
 Location: Bow, NH | maybe the gov't will start a "Treads for Trash" program and give us all money towards the purchase of new tires if we trade our old ones in..... |
    Location: Iowa | Better yet, maybe the gov't can start a "public option" tire company to compete with the private companies. That way if you can't afford new tires, the government will take care of you! Of course, then they'll want to dictate which brand of trailer you can buy...and when to junk your trailer when it's too old to haul anymore!! 52 52 |
      Location: Rocky Mount N.C. | http://www.washingtonpost.com/wp-dyn/content/article/2009/09/11/AR2009091103957_pf.html |
Location: On the road all the time. | Alot of people don't realize trailer tires are rated for a certain speed and driving the interstates doing 65-80 miles an hour will cause a side wall to blow with a load on it, that's how these tire manufacturers are getting out of their warranties! |
