paneling warping
illini
Reg. Mar 2009
Posted 2009-03-23 11:08 AM (#101938)
Subject: paneling warping
Has anyone had a problem with the paneling warping in the dressing room part of their trailer? We finished our Exiss trailer as a weekender and now the paneling is warping in places. Any ideas/
Edited by illini 2009-03-23 11:14 AM
Posted 2009-03-23 11:38 AM (#101943 - in reply to #101938)
Subject: RE: paneling warping
Did you insulate it before installing this paneling? Got any water leaks? Is it nice and dry inside? Moisture and high humidity = warping....
illini
Reg. Mar 2009
Posted 2009-03-23 12:13 PM (#101945 - in reply to #101938)
Yes we insulated it. No there is no leaks. The past year we have had alot of moisture, and we checked for leaks because of this.  Just wondering if there is any way to do somthing about it now, so we can stop this before the problem gets worse.
gabz
Posted 2009-03-23 12:50 PM (#101946 - in reply to #101945)
1000100100100252525
I've read of other people having that trouble when using thin paneling. It simply absorbs any and all moisture.
How thick is your paneling?
Some people have put 1/4" plywood behind the thin paneling.  I simply used 3/8" exterior beadboard plywood, rather than use 2 different surfaces.
Posted 2009-03-23 2:24 PM (#101951 - in reply to #101938)
The front side is finished, the back side isn't. The back side absorbs more moisture than the front. That is a cause of warping.
