trailer jacks
eswlnu
Reg. Mar 2009
Posted 2009-03-21 6:10 PM (#101875)
Subject: trailer jacks
have a problem..my electric over hydraulic jack is 5 years old and its shot i need to find out what brands there are to buy and how much they lift also wondering if a manual jack will work for our trailer its a C and C its 34 feet long with 12 foot living quarters thanks for your input
Hitch and go
Reg. Apr 2004
Posted 2009-03-23 5:22 PM (#101965 - in reply to #101875)
Subject: RE: trailer jacks
What brand hyd jack do you have?  I have never seen a hyd jack that could not be repaired cheaper than replacing it.
mnguy
Reg. Mar 2009
Posted 2009-03-25 4:59 PM (#102093 - in reply to #101875)
Is there something better out there I feel like Fred Flinstone when I wrestle my trailer up.
hogtownboss
Posted 2009-03-25 10:21 PM (#102108 - in reply to #101875)
10001001001002525
I agree with Hitch and go,  these jacks are actually simple to work on and there is not much to them.
What brand is your jack?
Yes, a manual jack will work.  The good thing about the manual jack is you can cancel your gym membership cause they will give you one heck of a workout!
mnguy
Reg. Mar 2009
Posted 2009-03-27 12:55 AM (#102204 - in reply to #101875)
What do you think about the electric drive motor from bulldog?  It's about 500 bucks.  Is this the cheapest upgrade option out there?
Posted 2009-03-27 8:43 AM (#102215 - in reply to #101875)
1000500100100100252525
get a maual jack and charge other people to come over and work  out leving the trailer up and down Have to looked on line at the web site of the maker of your jack and see if they have a manual on repairs to see if it is easy to fix??
mnguy
Reg. Mar 2009
Posted 2009-03-27 1:46 PM (#102232 - in reply to #101875)
 I have a new bulldog 12k so I don't think I need new parts.  I think I just need my horses to lift it for me ha ha.  I spend tons of money for this trailer and this is what I get what a joke.
hogtownboss
Posted 2009-03-27 4:29 PM (#102255 - in reply to #101875)
10001001001002525
Anytime you have moving parts you are subject to parts wearing out.  Just the facts of life.
If you have a bulldog 12-k jack the electric motor you mentioned above will work but I think it has to be a 2 speed jack.
But like I ask before what brand jack do you have?  There may not be much wrong with you jack...  There is not much to go worng with these type jacks.
Hitch and go
Reg. Apr 2004
Posted 2009-03-27 5:02 PM (#102258 - in reply to #101875)
The Bulldog electric motor will mount on the single speed bulldog jack.  I really do not like them.  Most installs require moving or adjusting the spare tire since it is on the opposite side of the crank handle and the motor is very slow.  If you want a electric motor and you have a 2-speed jack use an Equalizer motor.  Installing a motor on a single speed jack does not work for the long term. You will break the jack leg.  If you want to do it right and not worry about it install a hyd jack.
Posted 2009-03-27 10:18 PM (#102276 - in reply to #102258)
Originally written by Hitch and go on 2009-03-27 5:02 PM
Why would an electric motor break a jack leg?
Hitch and go
Reg. Apr 2004
Posted 2009-03-28 9:23 AM (#102287 - in reply to #101875)
Most people add a electric motor to a jack because it is too hard to crank.  Usually these trailers where sold as dressing room trailers and had LQs added to them.  The extra weight is putting more stress to the gears and shear pins.  When a motor is added to the jack it is forcing the gears to spin, causing more friction.  A person spend a jack alot slower, reducing friction.  The end result is the vertical drive gear crossthreads.  Cost the same to replace the jack as is it to fix it.
eswlnu
Reg. Mar 2009
Posted 2009-03-28 9:42 AM (#102288 - in reply to #101875)
the jack i have is called equalizer systems it raises the traler about 5 inches then the motor keeps running but it doesnt raise it any more..i dont know if the hydraulic fluid stops going into the system or what???thanks for any help
horsey1
Reg. Dec 2004
Posted 2009-03-28 11:18 AM (#102297 - in reply to #101875)
Make sure it has adequate fluid in it. If it is low, ATF (Dexron/Mercon) can be a suitable top off.
NATDA
Reg. May 2007
Posted 2009-03-28 11:50 AM (#102299 - in reply to #101875)
Could be low on fluid, or the pickup tube in the reservoir could have broken off, or fell off. Was the jack ever backed into? The pump is going into bypass when this happens. Does the trailer jerk or does it take a few seconds to move when you lower the trailer?
Equalizer can help you call them at 800-846-9659.
The problem is fixable much cheaper than even purchasing an electric.
Andy
hogtownboss
Posted 2009-03-28 12:34 PM (#102301 - in reply to #102288)
10001001001002525
FILL'ER UP and be done!
If it is moving at all and the pump and electric stuff is not "wet" you just need to fill the tank up with fluid. It you see "wet" around the pump/motor/tank anywhere, fill it up and work the jack up and down and look for leaks. This will have some presure while you are working it and you should be able to see fluid squirting or running out if there is a leak. (would be around where the hoses hook up to the pump or hyd switch or ram itself)
Posted 2009-03-28 12:48 PM (#102302 - in reply to #102287)
Originally written by Hitch and go on 2009-03-28 9:23 AM
Thank you for taking the time to respond. I can understand the gearing problem, but didn't correlate this to having the lower leg failing.
Most gearing problems of which I've encountered, were caused by a lack of proper maintenance. Several members of our club have experienced gearbox difficulties, single speed, dual speeds and electric motor drives of each.
In every case, the failure was due to the lack of proper lubrication in the gearbox. The single speeds have a removable cap, the dual speeds have zerk fittings. Five minutes time with a screw driver and some synthetic grease, will insure the gears' longevity.
Driving an unlubricated gear at a higher speed, or for that matter, any speed, will certainly cause additional friction and an eventual failure. Gears that are properly lubricated, usually won't encounter this problem.
eswlnu
Reg. Mar 2009
Posted 2009-03-28 10:13 PM (#102325 - in reply to #101875)
its totally full of fluid...and when i retract it it works awesome could it still be lack of fluid in gear box?????i suppose it mighti f so i have to find out were to lube it up...thanks
hogtownboss
Posted 2009-03-28 10:25 PM (#102327 - in reply to #102325)
10001001001002525
If I remember right I think the paper work on the one I had showed that the jack had to be extended to check the fluid level.
maybe gard or one of the other guys will jump back in a few and confirm...
eswlnu
Reg. Mar 2009
Posted 2009-03-29 12:36 AM (#102329 - in reply to #101875)
as far as i knew i didnt have to lubricate anything just make sure the reservoir was full or am i wrong?????
Tresvolte
Reg. Feb 2008
Posted 2009-03-30 7:47 AM (#102413 - in reply to #101875)
Chances are, if it is retracting fine, then you are probably low on fluid. It may just have a seal in it getting weak also. Call Equalizer. They will help you out.
eswlnu
Reg. Mar 2009
Posted 2009-03-30 10:36 AM (#102424 - in reply to #101875)
thanks
mnguy
Reg. Mar 2009
Posted 2009-03-30 2:13 PM (#102436 - in reply to #101875)
Do you guys gals feel that the hydraulic jack will take over the crank jack.  I would buy a hydraulic system over a crank anyday.  How do you guys feel?
Hitch and go
Reg. Apr 2004
Posted 2009-03-30 2:58 PM (#102441 - in reply to #101875)
As long as people buy on price the hand crank jack will be around.  Hyd jacks will be the norm on all LQs in the next few years.
mnguy
Reg. Mar 2009
Posted 2009-03-30 9:16 PM (#102464 - in reply to #101875)
How much more do you feel people will pay not to have to crank.  Is there a market for a better way to lift LQ?
Posted 2009-03-31 2:38 AM (#102482 - in reply to #102464)
Originally written by mnguy on 2009-03-30 10:16 PM
I think I paid about $900.00.... Hydraulic jack!!! Only way to go!
Tresvolte
Reg. Feb 2008
Posted 2009-03-31 7:35 AM (#102485 - in reply to #102464)
Originally written by mnguy on 2009-03-30 9:16 PM
Some people will pay, some people won't. That is the reason you see the hydraulic jack as an option.
mnguy
Reg. Mar 2009
Posted 2009-03-31 8:03 PM (#102527 - in reply to #101875)
I heard from a trailer company that something new was coming out in the next few months I am exited to see what it is.
Posted 2009-04-01 3:41 AM (#102543 - in reply to #101875)
I have wondered why the trailers with it's own air compressor for the rear suspension don't utilize this same compressor and reservoir tanks to supply an air cylinder or bag to jack/lift the trailer off the hitch ball. Once the trailer is lifted off the hitch and then lowered, there would need to be a way to lock it in place to keep it steady, or else it would pogo up and down as people and/or creature/critters entered and exited the trailer.
Tresvolte
Reg. Feb 2008
Posted 2009-04-01 7:23 AM (#102547 - in reply to #102527)
Originally written by mnguy on 2009-03-31 8:03 PM
Well Drew, why don't you tell us about it since you have the inside scoop.... http://www.coinincproducts.com/
mnguy
Reg. Mar 2009
Posted 2009-04-01 9:23 AM (#102554 - in reply to #101875)
The new jack is comming out in june.  It works very well for goosnecks in particular.  I have two discs out in my back so this will help tremendously.
Posted 2009-04-01 10:49 AM (#102561 - in reply to #102527)
Originally written by mnguy on 2009-03-31 5:03 PM
Drew... I find your postings posing as a third party disingenuous.  Instead of being deceitful, just come out and say you’re selling a trailer jack that could be of interest to us.
I’ve found this forum audience to be particularly harsh to poseurs and incompetents.  You will too.
genebob
Reg. Nov 2007
Posted 2009-04-01 2:15 PM (#102584 - in reply to #101875)
Better yet, buy an ad from Dave on this site and watch the orders come in.
Hitch and go
Reg. Apr 2004
Posted 2009-04-01 4:18 PM (#102590 - in reply to #101875)
That website leaves a little to be desired.  Hope the jack has more features.
mnguy
Reg. Mar 2009
Posted 2009-04-01 5:19 PM (#102593 - in reply to #101875)
The website will be up shortly with a side-by-side video comparison with other jacks out there.
Posted 2009-04-01 5:52 PM (#102594 - in reply to #102593)
Originally written by mnguy on 2009-04-01 6:19 PM
This best not be some sort of "April Fool" type deal!!!
eswlnu
Reg. Mar 2009
Posted 2009-04-05 5:36 PM (#102787 - in reply to #101875)
all right heres the deal.....i had my eq jack in at a dealer and talking with eq systems they couldnt figure out the problem so i had to send the manifold and pump back to eq systems for them to look at if they cant fix it i have to buy a new one can you believe that its 4 years old and its shot what a piece of shit....... i will never buy a nother one if its shot/......i might go to an electric one instead of a hydraulic one plus there cheaper....i would think that a jack should last longer then 4 years....and the warranty is only 3 years...... man am i mad....
mnguy
Reg. Mar 2009
Posted 2009-04-06 1:09 AM (#102803 - in reply to #101875)
How often do you use your landing gear, and what kind of conditions do you work or use your trailer?
eswlnu
Reg. Mar 2009
Posted 2009-04-11 10:22 AM (#103192 - in reply to #101875)
i use our jack just on weekends and its probably lowered and raised 2-3 times per weekend atr most.... easy conditions only during summer i dont use trailer during the winter.....theres no reason the jack is four years old and its shot??????if a guy spends 1300-1500 on a jack it should not be shot in four years   ....
Posted 2009-04-11 11:28 AM (#103195 - in reply to #103192)
Originally written by eswlnu on 2009-04-11 11:22 AM
Can it not be fixed? It's a little hydraulic pump and some lines and valves, can't be but so much wrong with it... You ain't going to make me believe it's "shot".... Maybe it's got a stuck relief valve from not using it in the winter, pump motor is dragging, e.i., low voltage, bad ground, etc... Wrong fluid??? Anyway, for less than $200.00 all your worries can be over.... You can go the ARM-STRONG route.   http://totaltrailerparts.com/store/index.php?main_page=product_info&cPath=219&products_id=2297
Good luck getting it fixed.... maybe take it to your local hydraulic repair shop.... The folks that rebuild pumps and cylinders, leave it on the trailer so they can see exactly what it's doing... Keep us informed on what you find out, there's several of us here that have Hydraulic landing gear.
eswlnu
Reg. Mar 2009
Posted 2009-04-11 12:10 PM (#103196 - in reply to #101875)
no the batteries are new..thetrailer place talked to the equalizer systems trouble shooting team on the phone they told the trailer place what to do and nothiung got fixed so eq systems said we cant think of anything else to do i guess you have to send it to us and well look at it so i did they said the pump or the manifold is shot and i need to buy a new pump or manifold which is 900 dollars and it comes with a 3 month warranty yea like im going to spend 900 dollars on a 3 month warranty id be better off spending an extra 600 and getting a new one with  a 3 year warranty.... i now i still cant believe that they say its shot it really pisses me off......
