Carpet removal tricks wanted
stef73433
Reg. Jun 2005
Posted 2009-03-17 7:14 PM (#101627)
Subject: Carpet removal tricks wanted
I am trying to take the carpet out of my GN area and floor in my trailer. The stuff is glued down for dear life. What can I do to make this an easier task? My hands are killing me and I only pulled like 6" up so far!!!
memory
Reg. Jul 2007
Posted 2009-03-17 10:15 PM (#101645 - in reply to #101627)
Subject: RE: Carpet removal tricks wanted
Warm it up with a blow dryer, as your peeling it back also use the blowdryer to soften the glue.
JFT
Reg. Jan 2009
Posted 2009-03-18 7:14 AM (#101654 - in reply to #101627)
If you are trying to pull it up in one piece that will be very hard. Try cutting small strips.
jakey1
Reg. Dec 2003
Posted 2009-03-18 7:30 AM (#101655 - in reply to #101627)
Try the blow dryer or better yet, a heat gun.  Use a vice grip pliers to get a good grip on the carpet rather than trying to pull it with your bare hands.
gabz
Posted 2009-03-18 12:10 PM (#101683 - in reply to #101627)
1000100100100252525
Put a heater in the area to help keep it warm. Blow dryer or heat gun, but if using the blow dryer, it will probably kick off when on High Heat setting.
I second the vise grips. Wonderful things. You can use them on trailer mats too!
burner718
Reg. Dec 2007
Posted 2009-03-18 7:33 PM (#101719 - in reply to #101627)
After you get it up, there will be residue. If you are reapplying new carpet, this is a must remove. You can get adhesive remover at Home Depot/Lowes/Hardware Stores....Kleen-Strip makes one.....just use adequate ventilation. If your're not putting down new flooring, the remover will clean it up real nice anyway.
