What's the difference between Sooner and Exiss trailers?
tool
Reg. Apr 2008
Posted 2009-03-05 3:31 PM (#100738)
Subject: What's the difference between Sooner and Exiss trailers?
So I was all set to buy a new 24' x7' Exiss gooseneck stock trailer.
Then the dealer called and said that they were sold out but would give me a Sooner for the same money.
What's the difference in these two trailers?
Am I gaining or loosing?
trguy4820
Reg. Jul 2008
Posted 2009-03-05 3:38 PM (#100739 - in reply to #100738)
Subject: RE: What's the difference between Sooner and Exiss trailers?
Same trailer - different stickers. Built in same plant on same line.
RTSmith
Posted 2009-03-05 3:49 PM (#100742 - in reply to #100738)
Same plant, same line, different materials. The Sooner extrusions are heavier. The rear end is heavier. When we had 1 of each here, the Sooner weighed 700# more (according to the MSO), with the difference being in materials content. The biggest difference is in the side slats as the Sooner will use a patented "triple hollow core slat". A pretty neat slat that is rippled on the outside, smooth on the inside, hollow in the middle. Same tires, axles, and neck. Sounds like a great deal to me, as there's usually $2,500 difference give or take.
RTSmith
www.SelectTrailer.com
trguy4820
Reg. Jul 2008
Posted 2009-03-05 4:01 PM (#100743 - in reply to #100742)
RTSmith
When did they start using heavier materials on the Sooner? Just curious. Did not know that.
trguy4820
hogtownboss
Posted 2009-03-06 10:08 AM (#100781 - in reply to #100738)
10001001001002525
Get the Sooner. They are both built buy the same company now, but Sooner has alway a little stronger than Exiss.
Think of it like this if you are buying a new truck it would be like buying a 1/2 vs. 3/4 ton or buying a loaded out truck vs. a base model.
We have had both Exiss and Sooner in LQ horse trailers, both was good trailers but again both was right before the Universal change over.
RTSmith
Posted 2009-03-06 10:14 AM (#100782 - in reply to #100738)
Sooner has used pretty heavy extrusions for some time. UTC still uses the same ones today, to the best of my knowledge. There is a floor plank that is exclusive to the Sooner Ranch stock trailer. The wall slat is used on many Sooners. And the last time I had a new Sooner & Exiss side by side the header reinforcements inside the rear frame were much heavier in the Sooner. A full .25" plate on the Sooner if I recall correctly. Hence the 700# or so.
Bun
Reg. Jan 2009
Posted 2009-03-10 8:03 PM (#101078 - in reply to #100738)
The Exiss has always been a bit lightly built...not as bad as the Keiffers or Colin-Arndts...but still light.
Posted 2009-03-10 10:07 PM (#101085 - in reply to #101078)
Originally written by Bun on 2009-03-10 9:03 PM
The "Sport" series perhaps, certainly not the "Events"
hounddog
Reg. Dec 2005
Posted 2009-03-11 3:27 AM (#101090 - in reply to #100738)
1000100100
If they build the SPORTS lighter then the EVENTS they  can't be much trailer thats for sure.
tool
Reg. Apr 2008
Posted 2009-03-12 6:30 PM (#101227 - in reply to #100738)
I got the Sooner SR724 Ranch and I'm VERY happy with it so far.
I took some time comairing it to the Exiss and their is substantial differences in my oppinion.
The Sooner was 7'2" high inside, VS the Exiss 7'
Much stouter rear gate construction and rear posts/corners. Different neck design gussted in the corners.
Different axles, Sooner uses Nevr Lube, Exiss uses EZ lube.
Triple Core Slats on the Sooner.
etc etc,
I would say the Sooner is a SUBSTANTIALLY better built trailer.
I guess I'll tell you in 10 years if my observations are correct.
Haha
BlazingCreekBar
Reg. Nov 2008
Posted 2009-03-12 6:59 PM (#101228 - in reply to #100738)
I am very pleased with our Sooner SE228 (Sooner Equine 2 horse 28 feet long) w/10' LQ 8'w 7'6" tall
We sold our 2h bp wdr Cherokee Super chief that we special ordered.  We knew to get to a LQ trailer with the options we wanted the best plan was used.
Ultimately I was getting very disappointed with all the local talent.  I like shiny, clean and sharp looking toys and frankly (No offense to anyone) not everyone cares for their horse trailer like that.
After well over 12 months of searching we fell upon our current Sooner.
Short of the long, We love it.  Our model (2004) I believe was pre the merge of the three companies.
Yes I discovered the never-lube hubs and many other well built tid bits of the trailer over the last year.
I hope this one is with us for a long time.
Good luck with your searching
Edited by BlazingCreekBar 2009-03-12 7:01 PM
