I love you very much, and I truly cherish your presence in my life. I would never wish to criticise you in any way. However, there are a few trivial details regarding our relationship that I think might bear your consideration.
First of all, I am already aware that horses can run faster than I can. I do not need you to demonstrate that fact each time I come to get you in from the field.
Please remember that I work long and hard to earn the money to keep you in the style to which you have become accustomed. In return, I think you should at least pretend to be glad to see me, even when I'm carrying a bridle instead of a bucket of feed.
It should be fairly obvious to you that I am a human being who walks on only two legs. I do not resemble a scratching post. Do not think that, when you rub your head against me with 1,000 pounds of force behind it, I believe that it wasn't your intention to send me flying. I am also aware that stomping on my toes while you are pushing me around is nothing but adding injury to insult.
I understand I cannot expect you to cover your nose when you sneeze, but it would be appreciated if you did not inhale large amounts of dirt and manure prior to aiming your sneezes at my face and shirt. Also, if you have recently filled your mouth with water you do not intend to drink, please let it all dribble from your mouth BEFORE you put your head on my shoulder. In addition, while I know you despise your worming medication, my intentions in giving it to you are good, and I really do not think I should be rewarded by having you spit half of it back out onto my shirt.
Sometimes, I get the feeling that you are confused about the appropriate roles you should play in various situations. One small bit of advice: Your stone-wall imitation should be used when I am mounting and your speed-walker imitation when I suggest that we proceed on our way, not vice versa. Please also understand that jumping is meant to be a mutual endeavour. By "mutual", I mean that we are supposed to go over the jump together. You were purchased to be a mount, not a catapult.
I know the world is a scary place when your eyes are on the sides of your head, but I did spend a significant amount of money to buy you, and I have every intention of protecting that investment. Therefore, please consider the following when you are choosing the appropriate behaviour for a particular situation:
When I put your headcollar on you, attach one end of a lead rope to the headcollar, and tie the other end of the lead rope to a post or ring or whatever, I am indicating a desire for you to remain in that locale. I would also like the headcollar, lead rope, post, etc., to remain intact. While I admit that things like sudden loud noises can be startling, I do not consider them to be acceptable excuses for repeatedly snapping expensive new lead ropes (or headcollars or posts) so that you can run madly around the yard creating havoc in your wake. Such behaviour is not conducive to achieving that important goal that I know we both share --- decreasing the number of times the veterinarian comes out to visit you.
By the same token, the barn aisle was not designed for the running of the Derby and is not meant to serve as a racetrack. Dragging me down the aisle in leaps and bounds is not how "leading" is supposed to work, even if someone happens to drop a saddle on the floor as we're passing. Pulling loose and running off is also discouraged (although I admit it does allow you to run faster).
I assure you that blowing pieces of paper do not eat horses. While I realize you are very athletic, I do not need a demonstration of your ability to jump 25 feet sideways from a standing start while swapping ends in midair, nor am I interested in your ability to emulate both a racehorse and a bucking bronco while escaping said piece of paper. Also, if the paper were truly a danger, it would be the height of unkindness to dump me on the ground in front of it as a sacrificial offering to expedite your escape.
When I ask you to cross a small stream, you may safely assume that said stream does not contain crocodiles, sharks, or piranhas, nor will it be likely to drown you. (I have actually seen horses swimming, so I know it can be done.) I expect you to be prepared to comply with the occasional request to wade across some small body of water. Since I would like to be dry when we reach the other side of the stream, deciding to roll when we're halfway across is not encouraged behaviour.
I give you my solemn oath that the trailer is nothing but an alternate means of transportation for distances too long for walking. It is not a lion's den or a dragon's maw, nor will it magically transform into such. It is made for horses, and I promise you that you will indeed fit into your assigned space. Please also bear in mind that I generally operate on a schedule, and wherever we're going, I would really like to get there today.
For the last time, I do not intend to abandon you to a barren, friendless existence. If I put you in a turn-out paddock, I promise that no predators will eat you, and I will come back in due time to return you to your stable. It is not necessary to run in circles, whinny pathetically, threaten to jump the fence, or paw at the gate. Neither your stable mates nor I will have left the premises. The other horses standing peacefully in adjacent paddocks amply demonstrate that it is possible to enjoy being turned out for exercise.
Finally, in closing, my strong and gentle companion, I would like to point out that, whatever might happen between horses and their people, we humans will always love you. In fact, our bonds with you help create new bonds among ourselves, even with total strangers. Wherever there are horses, there will be "horse people", and for the blessings you bestow upon us, we thank you.
Most sincerely yours,
Your Adoring Owner | |
    Location: Vanzant, Missouri | That was great...and soooo true | |
     Location: Corpus Christi, Texas | Thank you for the much-needed laugh and the humorous start to my day! Leslie | |
| Aw man. He's got my horse's twin! Poor fellow. | |
     Location: Where the wind comes sweepin' down the plain... | I love it! We have all been there at one point and time... If not time after time after time.... | |
 Location: Tucumcari NM | Reading this piece makes for a nice ending to my day. Thanks!
Marla | |
      Location: Rocky Mount N.C. | A Letter from Your Horse (original version) - When you are tense, let me teach you to relax. When you are short-tempered, let me teach you to be patient.
- When you are short-sighted, let me teach you to see. When you are quick to react, let me teach you to be patient.
- When you are angry, let me teach you to be serene. When you feel superior, let me teach you to be respectful.
- When you are self-absorbed, let me teach you to think of greater things. When you are arrogant, let me teach you humility.
- When you are lonely, let me be your companion. When you are tired, let me carry the load.
- When you need to learn, let me teach you. After all, I am your horse.
And now, the REAL DEAL.................... - When you are tense, let me teach you that there are lions in them thar woods and we need to leave NOW!
- When you are short-tempered, let me teach you to slog around the pasture for an hour before you can catch me.
- When you are short-sighted, let me teach you to figure out where, exactly, in the 40 acres I am hiding.
- When you are quick to react, let me teach you that herbivores kick much faster and harder than omnivores.
- When you are angry, let me teach you how well I can stand on my hind feet because I don't feel like cantering on my right lead today.
- When you are worried, let me entertain you with my mystery lameness.
- When you feel superior, let me teach you that, mostly, you are the maid service.
- When you are self-absorbed, let me teach you to PAY ATTENTION. Remember how I told you about those lions in them thar woods?
- When you are arrogant, let me teach you what 1200 lbs of "YAHOO LETS GO!" can do when suitably inspired.
- When you are lonely, let me be your companion. Let's do lunch. Also, breakfast, snack and dinner.
- When you are tired, don't forget the 600 lbs of grain that needs to be unloaded.
- When you are feeling financially secure, let me teach you the meaning of "Veterinary Services".
- When you want to learn, hang around - I'll learn ya!
 Location: Lexington, SC | My, how you both have enlightened my day! It seems we all have the same horse. Thank you for sharing. | |
