 Location: albany, ga | When using the pump and water out of the water holding tank do I need to cap off the water inlet for the water connection? I have never ran out of the holding tank before because I have always been hooked up to the water supply. When I ran the pump water came back out through the water supply connection. I was unsure if that inlet needed to be capped off. It is not the inlet for the water holding tank, it is the inlet for the constant water supply. |
