  Location: Alabama | can a 04 2500hd as burner handle a 4 horse featherlite haulin 2-3 horses |
      Location: Home of Wild Turkey Whiskey | 6.0 or 8.1?, the towing capacity is 12K for a 6.0 Regular Cab so you would be safe unless the trailer is a LQ. Towing capacities are reduced on Ex-cabs and crew cabs, due to truck is heavier. I have the 6.0 in an Escalade and we pull 3 in a BP with no issues. |
      Location: Rocky Mount N.C. | 2500HD Ext Cab 4WD SB 6.0L V-8 10,100 2500HD Ext Cab 4WD LB 6.0L V-8 9,900 2500HD Ext Cab RWD SB 6.0L V-8 10,300 2500HD Extended Cab RWD LB 6.0L V-8 10,200 The way it looks, you're good for around 10000# with a 6.0 liter gas, automatic, 4.10 geared, GM,2500 HD. http://www.trailerlife.com/images/elements/883783_Towing_Guide.pdf
Edited by retento 2009-03-02 12:24 PM
