 Location: stephenville texas | Any thoughts on these trailers? Please post good and bad. Are they considered a high end trailer like a 4 star? Thanks! |
      Location: Home of Wild Turkey Whiskey | They make a good trailer, but it's more in line with a Hart, than it would be with the 4 Star. They use the FRP for the roof, some folks like it, I have had bad experiences with it leaking after some years. The people that like it, usually make a claim about it insulates the ceiling ect. The big difference in the high end trailers(4 Star, Bloomer, Elite) is those guys use a much heavier grade of aluminum for the wall studs, bottom and top rails. Now having said that, if you are hauling once or twice a month on average then those trailers will last forever, If you are hauling to 2 shows every weekend then you might want to step up to the high end trailers. I would assume that since you are asking, you are part of group 1. After seeing your location, just look at what the pro's are hauling, look for the ones that don't have a trailer deal(as I'll pull anyones trailer if it's free), see what the pros are spending their own dollars on.
Edited by HWBar 2009-02-22 6:28 AM
   Location: MI. | I found Cimarron's specs but not 4-star's. Cimarron...extruded aluminum floor at 6 inch centers, .050 aluminum sides, .090 top and bottom plate. I'll keep searching for 4-star's specs.......
Edited by Gone 2009-02-22 7:21 AM
      Location: Home of Wild Turkey Whiskey | You can look for specs if you want, the extruded floor you talk about has no I-Beams as it's all integrated, that's how they claim the 6" spacing, very difficult to install holding tanks under it, so they will LQ prep the trailers buy cutting out a section and installing a flat piece of aluminum there. Also as far as the wall studs go I can send a self tapping screw into a Cimmaron, on a 4 Star you have to pre-drill the hole. I have been all over, on top of, and under, most brands of trailers I just finished a Cimmaron and it left here last week. |
   Location: MI. | Thanks for the info. I personally wish I could tour some trailer places... |
      Location: Home of Wild Turkey Whiskey | From the outside most of these trailers look the same, there are a few manufacturers that use this FRP, for the roof, some use it in the dividers, and slant wall. It has been around for a long time. The biggest difference in these trailers I have found is in the actual aluminum, most folks just see aluminum, the upper end trailers use a much thicker aluminum for everything, look at the frame around the windows on a high end trailer, then go look at the lower end ones. There is an incredible difference. Same with the wall studs and bottom rails. Having said all this if you are not going to drag a trailer around but a few huindred or few thousand miles a year, this stuff doesn't matter. Some of these show/rodeo folks drag around a trailer 30-75K a year, these people are pulling the top brands of trailers, unless they are pulling a sponsors trailer, and it that case what does it matter. |
 Location: stephenville texas | Please list all of the higher end trailers in your opinon |
      Location: Home of Wild Turkey Whiskey | Top end trailers are 4 Star, Bloomer, Elite and C&C. Then you have some that are nice but just not in the same league as these. I have worked on just about every brand out there, and studied them all. |
| HBar dont you think Hart is at the same level as 4star? You know these trailers better than me but when I looked at the welds and the material they both used and the designs I felt like they were equal. What do you think? |
      Location: Home of Wild Turkey Whiskey | Originally written by AQHA 123 on 2009-02-22 4:21 PM
HBar dont you think Hart is at the same level as 4star? You know these trailers better than me but when I looked at the welds and the material they both used and the designs I felt like they were equal. What do you think? Nope, I'll say that Hart is the best of the manufacturers that use the FRP roof, all of the manufacturers that use the FRP roof use the same top rail, it is not near as beefy as the top rail in a 4 Star/Bloomer ect. The way the roof is attached to the top rail lends itself to leaks after some years. I have a Hart coming tomorrow for some repairs, the slideout is leaking, that softened the glue under the linolium, so I am replacing the floor covering with a laminate flooring. |
| Does a synthetic laminate hold up better than a vinyl floor for a LQ application? (sorry OP, I don't mean to highjack)Is it the sun that breaks down the seals on the fiberglass tops and makes them leak? My trailers are kept in the barn, I hope to not have this problem. |
       Location: western PA | Originally written by AQHA 123 on 2009-02-22 7:52 PM Does a synthetic laminate hold up better than a vinyl floor for a LQ application? Either one will probably last as long as your ownership of the trailer Is it the sun that breaks down the seals on the fiberglass tops and makes them leak? The sun will weaken the caulking as well as the fiberglass. Replace any silicone caulking with a marine polyurethane and it will seal longer. A barn storage will significantly decrease the maintenance of your trailer. Gard |
    Location: Lockport, Illinois | Originally written by HWBar on 2009-02-22 8:24 AM Also as far as the wall studs go I can send a self tapping screw into a Cimmaron, on a 4 Star you have to pre-drill the hole. [/QUOTE I have a 4-Star and I know what HWBar is talking about. I bought SS self tapping screws when I was doing the conversion. I couldn't beleive that I had to drill a starting hole in the aluminum with the SS self taping screw. The aluminum was harder than the SS. |
   Location: Little town in Pa | If you want to tour a trailer plant, Lakota does give of their plant in Indiana. http://www.lakotatrailers.com/about/history.asp |
| Had several trailers that you have mentioned. I just purchased a '09 Cimmarron and so far so good. Went with it due to the FRP (we have lots of hail around here and skinned roofs don't do as well with hail). Put 10-15k miles a year on them and would put Cim. and Hart up against all others. The floor is another selling point to me as it is put together like a puzzle. My experience with I beam/sheeting floors is that they have a tendency to "oil can" and after a few years, they sag where the horse stands. By the way, the Bloomer dealer told me that Bloomer has the same floor as the Hart and Cim. I looked at $100k 4 Stars, and questioned how they could put cheap exposed weather stripping on the drop frames & doors, that would eventually come off. I chose Cim. over Hart due to price, removable fenders, and a few other minor features. The owner of Cim. I was told, was a manager for Hart for years. As like spouses, we all like something a little different! |
| I didn't have a 4star dealer in my area so I compared the Hart and the Elite. Both looked great but I liked the design and feel of the Hart so I went with that. The trailer this one is replacing is a Featherlite, so it should be a big step up from that. I'm a little bummed there wasn't a 4star place closer, I would have liked comparing that brand as well. |
Location: Fort Lupton, CO | So what do you do Mr HWBar?? |
| Funny, no one mentioned Sundowner as one of the "High End" companies. Sundowners 720 & 725 are some of the strongest trailers out there. |
      Location: Home of Wild Turkey Whiskey | Originally written by Trailers101 on 2009-03-27 4:10 PM
So what do you do Mr HWBar?? Horse trailer conversions, and sell equipment. I have been upside down in just about every brand of trailer. Hart/Cimmarron included.
Edited by HWBar 2009-03-27 5:23 PM
 Location: Vero Beach Fl | Have you worked on any Shadow trailers.. if so what is your opinion on that brand. The more recent year models. |
Location: Fort Lupton, CO | Here is some info for those interested. The roof panel on Cimarron and Hart trailers is not FRP. FRP is Fiber reinforced plywood. The roof panels on current Hart and Cimarron trailers have a composite honey comb style center in a fiberglass sandwich and a special UV protective cover on the top side. It has actually proved very robust over time and is quieter and cooler than the thinner aluminum roofs. One of the highest mileage trailers I know of is a Hart that is well past its million mile mark. Cimarron has one of the thickest walls in the industry and probably the strongest doors I have seen. |
       Location: western PA | Another bit of information: FRP, when used in the fiberglass construction industry, means fiberglass reinforced plastic, not fiberglass reinforced panels or plywood. Plastic is a generic term for the various resins used in the layups, and does not describe the core material. The resins hold the fiberglass in a particular shape, while the fiberglass provides the layup with strength. The addition of various core materials, adds greatly to the total overall strength and rigidity of the construction. Gard
Edited by gard 2009-03-28 9:04 AM
Location: Poolville, Texas | Cimmarron builds a great trailer. They are getting very popular around Weatherford with the cutters. Mike Terry calls the shots at Cimmarron and he is incredible when it comes to his demand for quality. He ran Hart for a long time, and does a great job. They have a big selection at NRS in Decatur. 4 Star, Bloomer, Platinum, Elite, Cimmarron are all really good trailers. I have owned a nd pulled all of them. We hook alot of the medium duty trucks to all of the above and that is where you seperate the "players from the fans"...A big truck will tear up alot of trailers. |
Location: Homer, AK | I sure am glad to find this thread, I was going to start a new post but we'll see if I can get some advice just joining in here since the post is so recent. I am trailer shopping for a 4 horse with large tack or weekender, on the net. Looking for used to maximize what I get for the price I spend. The trailer will be hauled a minimum of 2,000 miles to get it home and I plan on hanging on to it for a long time so really want the right trailer! I have been looking at ( via the net) 4 Stars, Elite, Hart ,CM Norstars, and a few C&C's. My number one priority is durability. I travel on lots of rough or uneven roads, live in a corrosive area ( bluff on the sea), haul 1,200-1,500lb horses, and often get sideways rain that could find its way into a sealed coffee can! ( so dont want any leaky roof problems) :) . I have spent a lot of money repairing my steel frame/aluminum skin current trailer and am ready for an upgrade. I had thought I was only going to consider a Hart as I had hauled my friend's 06 4 horse and found it pulled like a dream, was quiet and was pretty impressed by the structure. A few things about it bothered me though, such as flimsy wheel wells that are so dinged up, the plastic gaurds wont stay on. The sheet metal on the siding seems quite thin compared to the mid 90 LQ Sundowners I have owned. Personally , I've seen very few Harts in the 7' plus width, and her 6' ? " Hart stalls were just too short length for my horses. I havent ruled Hart out but am trying to do some structural comparisons between some of the others I have mentioned shopping for. I am looking at a 04 CM Norstar and am now a little concerned about the composite roof having leakage issues. I climbed up top of my 97 Aluminum roofed Charmac and was appalled at what is considered a factory standard roof! I bet there is a case of Caulking on the upper exposed roof nuts. To it's credit though, it doesnt leak. Have to say the 4 star's thickness and grade of aluminum used in structural support is VERY appealing as a commercial fisherman know high quality welding and heavy grade aluminum is incredibily strong and lasts forever. I am just trying to weed out fact from hype and get to the performance of these trailers. Any input you all have to contribute I appreciate. Many Many questions I have had , were answered and am narrowed down to these trailers. Just feeling anxious to know as much as I can to make the right choice. |
Location: Fort Lupton, CO | There is a Cimarron Trailer review on this site... http://horsetrailerreview.com/ |
Location: West Jefferson, Ohio | When shopping for a trailer, don't forget about Eby. When comparing the quality of our product to that of others you will find that that our pricing and service are very competitive. One way of sharing the confidence that Eby has in it's product is by conduction plant tours at all three of their facilities. I am located in Ohio where the livestock trailers are manufactured. I would be happy to personally give you a tour of the facility here. Steve Rittenhouse M.H. Eby, Inc. |
Location: Kentucky | AQHA 123 You should call Randy Stamper at Hart. I believe that HWBar is mistaken about the roofing material on Hart trailers. And they are one of the better aluminum trailers.
Edited by Whisper 2009-03-31 6:38 PM
 Location: Indiana | Originally written by HWBar on 2009-02-22 11:34 AM
Top end trailers are 4 Star, Bloomer, Elite and C&C. Then you have some that are nice but just not in the same league as these. I have worked on just about every brand out there, and studied them all. Don't forget Platinum Coach Trailers - they are definetly top end. According to Barrel Horse News when the interviewed the Top 15 NFR Barrel Racers four hauled a Platinum. There were also four that hauled a Bloomer but one of those was sponsored by Bloomer. If I can find the article I can tell you how many of the other trailers were in that 15. |
     Location: Where the wind comes sweepin' down the plain... | Here are some reviews of some of those mentioned... http://www.horsetrailerworld.com/Home/contribute/Homepage/MrTruck054-06hart/hart.asp http://www.horsetrailerworld.com/home/contribute/Homepage/MrTruck0905/mrtruck.asp http://horsetrailerworld.com/home/contribute/Homepage/Platinum2/platinum2.asp http://www.horsetrailerworld.com/Home/TRElite02.asp Here is a thread about 4 Star and Hart... http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=10435 And another thread about best trailers.... http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=9761 And one about Bloomer... http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=9257 |
      Location: Home of Wild Turkey Whiskey | Originally written by Whisper on 2009-03-31 10:57 AM
I believe that HWBar is mistaken about the roofing material on Hart trailers. Wanna Bet? This is straight from Harts Site.
http://www.harttrailer.com/hart_difference_in_the_details.html |
     Location: Where the wind comes sweepin' down the plain... | HWBar - what is it you have against the Hart roof? I've looked at the samples that they have had at the World Show and really liked it. |
      Location: Home of Wild Turkey Whiskey | Originally written by Tresvolte on 2009-04-01 8:01 AM
HWBar - what is it you have against the Hart roof? I've looked at the samples that they have had at the World Show and really liked it. It's not Hart, it's the FRP I don't really like, It seems like it breaksdown after years of service and starts to leak. Now having said that, I have had to fix leaks on just about every brand of trailer, but when these start to leak they tend to be much harder to get to stop. I don't know if it is the bolts they use to hold it all together, the flexing of the joint, or what the problem is. but I'm just not a big fan of the stuff. The people that sell them, always want to brag about insulating properties, and the ability to walk on it. It probley has about as much insulating properties as a styrofoam cup, and I don't need to walk on the roof of my trailer. |
    Location: Kinston, NC | We have a similar roof design (although twice as thick) and I was not impressed with the FRP samples versus alternatives. We opted to go with the 1" thick honeycomb with aluminum on both sides, much stronger and more insulation (and costs more). Bartley Heath bartley@DoubleDTrailers.com Buy Factory Direct Aluminum Trailers at DoubleDTrailers.com |
    Location: Kinston, NC | While we are quoting from Hart's site: "All structural aluminum extrusions are 6061 alloy with T6 temper to get the most muscle per ounce, 46,000 PSI structural strength, 22% stronger than steel yet only 1/3 the weight." I think this statement is somewhat misleading. To me, that would mean we could build aluminum trailers that weighed 1/3 as much as steel. We use the exact same aircraft aluminum 6061-T6. How that statement should read is that aluminum is 1/3 the weight, so for comparing steel ounces vs alum ounces, your aluminum has to be 3 times as thick. Needless to say, it isn't 22% stronger (per ounce) AND 1/3 the weight. Those statements should be independant of each other. By the way, I think Hart builds a fantastic trailer, which is why we have designed our all aluminum trailers in similar fashion. Bartley Heath bartley@DoubleDTrailers.com Buy Factory Direct Horse Trailers at DoubleDTrailers.com |
