WANT FANCY WHEELS for our SUNDOWNER
hogtownboss
Posted 2009-02-10 10:47 PM (#99214)
Subject: WANT FANCY WHEELS for our SUNDOWNER
10001001001002525
Our 2004 Sundowner 8010 Signature Series 3 horse trailer has original equipment 8 lug 16" steel mod wheels and we are wanting to upgrade to some fancy wheels since the trailer has polished stainless steel side panels I want something that stands out.
alum?  chrome steel?  any ideas???
I have 4 factory alcoa alum. off of a 1997 Ford F-250 but was told they are only rated for 3415 lbs each and we are running 2 7-k axles, so that no work.
IcePonyGoddess
Reg. Nov 2006
Posted 2009-02-10 11:37 PM (#99215 - in reply to #99214)
Subject: RE: WANT FANCY WHEELS for our SUNDOWNER
500100100252525
Heck...just got for it....put spinners on that trailer. HA!
Have fun shopping for new wheels.
hogtownboss
Posted 2009-02-10 11:47 PM (#99216 - in reply to #99215)
10001001001002525
Yeah, spinners or some bling bling 20's that will match my rolling mirror?
Posted 2009-02-11 12:20 AM (#99217 - in reply to #99214)
Originally written by hogtownboss on 2009-02-10 7:47 PM
For $8 bucks weigh your fully loaded and level running trailer.  See what the trailer wheels are loaded to.  Perhaps your Alcoa wheels may be up to the job you have...
Posted 2009-02-11 1:57 AM (#99221 - in reply to #99214)
Probably the best there is so far as an aluminum trailer wheel... http://www.alcoa.com/alcoawheels/north_america/en/fsw/driver/trailer/tr_home.asp
http://www.southwestwheel.com/store/p-3006-16x7-alcoa-aluminum-trailer-wheel.aspx
http://www.alcoa.com/global/en/products/product.asp?prod_id=1188
Three different styles of aluminum wheels on this page rated as high as 3960#   http://www.trailertiresandwheels.com/site/1284278/page/910765
This is new, been out less than a year... http://www.trailertiresandwheels.com/site/1284278/product/AW1614
They got the tires also..... http://www.trailertiresandwheels.com/site/1284278/product/RG614
Don't know anything about the ones pictured below, other than they are 17.5's on a 18' sw, 4 horse slant...
<script> window.setTimeout("watermark()",50);
Edited by retento 2009-02-11 5:40 AM
Posted 2009-02-11 6:58 AM (#99226 - in reply to #99214)
I doubt the Ford wheels will fit the stud bolt pattern. Most Dexter Axles have the GM bolt pattern.
See Retento post about Alcoa.  thats the best choice for high psi wheels.
brushycreekranch
Reg. Jun 2006
Posted 2009-02-11 9:23 AM (#99239 - in reply to #99214)
500100100100100
I have Alcoa wheels on both my horse trailers. Love them!  Also have them on the two trucks that pull them.  Every flat tire that I have had in the last few years, where simulator related... ie ...sliced valve stems .  So, it is Alcoa all the way!
greyhorse
Reg. Nov 2005
Posted 2009-02-11 9:45 AM (#99246 - in reply to #99214)
I vote for Alcoa's. I have 17.5's on my trailer and they look pretty nice without being too flashy or hard to keep clean.
jim bob
Reg. Jan 2008
Posted 2009-02-11 10:43 AM (#99254 - in reply to #99214)
tHE PROBLEM WITH ALUMINUM WHEELS
Aluminum wheels are great; BUT you have to make sure they are rated heavy enough for your trailer.  If you have a tire that needs repairing on the road; not every place will repair a tire mounted on a high dollar aluminum rim.  Also; if you run your trailer in road salt in the winter, it will pit aluminum wheels.  What we do at our dealership for good looking wheels; is add Stainless Steel simulators.  They cover the entire wheel; salt don't hurt them, and if they do get damaged, they are much more efficient to replace than aluminum wheels.  We are a Sundowner dealer, and we put a lot of the SS wheels on our trailers.
Posted 2009-02-11 10:57 AM (#99256 - in reply to #99214)
I put a set of these on our last trailer.... Cleaned it up pretty good and kept the strength of the steel wheels. Real easy to keep clean.
http://www.jaeeagle.com/popup_image.php?pID=367
http://www.jaeeagle.com/product_info.php?cPath=28_168_66_132&products_id=367
Posted 2009-02-11 11:10 AM (#99257 - in reply to #99214)
I also have a set like Retento's on both of our trailers. They bolt on, so they can't shift and cut the valve stems. They are secure so they can't pop off on rough roads. They are solid stainless, so they don't rust and clean up nicely. Much less expensive than a new set of rims and centers. They cover the whole wheel and will upgrade the appearance of any steel wheel.
I bought them From Richard T Smith's parts dept. They have excellent prices, fast service and nominal shipping costs. Call Roger @ 931-685-4040 and he can ID what you need & UPS it ASAP.
Tresvolte
Reg. Feb 2008
Posted 2009-02-11 11:17 AM (#99258 - in reply to #99214)
http://www.phoenixusa.com/product.phtml?p=51&cat_key=19
DD_TrailerMan
Reg. Jul 2008
Posted 2009-02-11 11:21 AM (#99259 - in reply to #99214)
here are the rims we use, they are quite sharp.  Haven't see this type on any other trailer...
http://www.doubledtrailers.com/xml/TrailerDetail.aspx?id=183781
BH
Spooler
Reg. Aug 2006
Posted 2009-02-11 9:26 PM (#99301 - in reply to #99214)
50025
ALCOA has some G load range rated wheels.... That's what I would get.
hogtownboss
Posted 2009-02-11 9:57 PM (#99304 - in reply to #99214)
10001001001002525
WOW so many to pick from....
The Alcoa wheel that I have fit perfect, but not sure about the weight deal.  Manufacture said their wheel are designed to handle more weight than listed, but nothing in writing.  Older Ford, Dodge and GM have the smae bolt pattern, some have larger studs.
I like the SS wheel covers, the only ones I have found here local are a chrome plasitc cover.
Thanks for the websites to look at and ideas.
HTB-Kelley
headhunter
Reg. Oct 2004
Posted 2009-02-12 1:34 AM (#99322 - in reply to #99214)
50010010025
We got chrome wheel simulators for the hubby's E450 chassis cube van.  The cost of wheel simulators was a fraction of the cost of chrome wheels with the weight rating needed for the E450, and you cannot tell they are not the real deal.
Tresvolte
Reg. Feb 2008
Posted 2009-02-12 7:41 AM (#99334 - in reply to #99214)
This Alcoa wheel is rated for 3750 pounds and is designed for trailer use. They also have other styles available with the same rating. http://www.alcoa.com/global/en/products/product.asp?prod_id=1188
Posted 2009-02-12 7:44 AM (#99336 - in reply to #99259)
Originally written by DD_TrailerMan on 2009-02-11 12:21 PM
BH
Bartly, what make wheel is that? That's sharp!!
hogtownboss
Posted 2009-02-12 9:28 PM (#99404 - in reply to #99334)
10001001001002525
Tresvolte,  I have a stupid question about the wheels that alcoa has on the website you listed.  The upper part of their listing shows max of 3750 and max psi of 110, but in the lower secton showing "attributes" they list weight rating of 3415 and 95psi.  What does this mean???
If the 3415 and 95psi is like a standard, but they are actually rated at 3750 and 110psi, the wheel I have will work just fine.  RIGHT???
Posted 2009-02-13 12:21 AM (#99411 - in reply to #99404)
Originally written by hogtownboss on 2009-02-12 10:28 PM
You did note the footnote...
3 Capacity ratings as dual or single in highway service -- bias-ply or radial.
I've sent a request for clarification of the number differences, but I think they are going to say one set 3750 and 110psi are MAXIMUMS and the second set 3415 and 95psi are OPERATIONAL...i.e. if you want a long life out of them...
Edited by PaulChristenson 2009-02-13 12:27 AM
Tresvolte
Reg. Feb 2008
Posted 2009-02-13 7:40 AM (#99419 - in reply to #99404)
Originally written by hogtownboss on 2009-02-12 9:28 PM
I know that a few years ago Alcoa changed ratings on their wheels. The standard wheels were rated at 3415 & 95psi. My understanding is that they made changes to the old wheels to acheive the higher rating, although, there is always the possibility that they may have raised the rating on the old wheel without any changes.
Paul may have hit the nail on the head. 3750 & 110psi may be the maximums now. I am curious to see what response he gets from them.
hogtownboss
Posted 2009-02-13 11:26 PM (#99444 - in reply to #99411)
10001001001002525
Sorry, I am still lost here.  I am using GOODYEAR G614's on this trailer, I know the weight rating is 3750 but don't remember the psi right off.  I'm sure ya'll do.
I guess I might just stick with the original steel wheel and buy the SS covers ya'll listed.
Posted 2009-02-14 4:28 AM (#99445 - in reply to #99214)
3042 at 80 psi
3750 at 110 psi
Rims should be stamped for the max. load/psi rating.
http://www.goodyear.com/rv/products/g614rst.html
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
Edited by retento 2009-02-14 4:31 AM
hogtownboss
Posted 2009-02-14 2:21 PM (#99464 - in reply to #99445)
10001001001002525
Now with that being said, after looking at the rv chart since my trailer has 2 7-k axles I will need to run my tires at 100psi to be at the rated weight?
If I figured it right, 2 7-k's equal 14-k / by 4 should be 3500lbs per each tire/wheel.
My stock steel wheels are stamped on th e inside 3750# @110psi!  The alcoa Ford wheels I have are not stamped.
Posted 2009-02-14 3:11 PM (#99467 - in reply to #99214)
HTB.... The 265 lrE tire on the 16x7 wheel was rated at 3415....  Might trying to get someone behind a Ford parts counter, to look up the correct wheel for the 1997 F-250 truck, it may have the wheel weight rating listed.
hogtownboss
Posted 2009-02-14 7:48 PM (#99478 - in reply to #99467)
10001001001002525
I tried going to Ford first with no luck. They are the ones who said to contact Alcoa direct, that is where I got the figures from.
Posted 2009-02-14 9:00 PM (#99481 - in reply to #99214)
My Ford and trailer axles have the same bolt patterns. BUT, they have different stud diameters and wheel offsets. You might want to check yours before making a purchase.
hogtownboss
Posted 2009-02-14 9:33 PM (#99485 - in reply to #99481)
10001001001002525
Originally written by gard on 2009-02-14 9:00 PM
I put one of the wheels on last weekend just to see and they fit perfect.  I could not beat the price so I could not pass them up.  FREE, I sold a 1997 Ford F-250 4x4 to a older farmer and he told me "I dont need them there fancy wheels" so I had a set of factory steel wheels I give him and he brought me the Alcoa wheels back.
That is the reason I was wanting to know about the weight rating on them.  I think we have talked ourself into ordering the ss covers that ya'll told me about.
Thanks, HTB-Kelley
Posted 2009-02-18 12:18 PM (#99690 - in reply to #99214)
Here is the e-mail from Alcoa...
Hello Paul,
The copy description, including 3,750 at 110 psi is a "blanket statement" for all trailer wheels.  However, the load rating quoted in the copy statement is for the 16" Classic wheel.  The wheel you are interested (part#167031) is our LTS 5-spoke wheel, which was tested at 95 psi and has a load rating of 3415.  If maximum load rating is your ultimate goal, I would suggest (part#167041) our Classic-8 16"x7" wheel with 3,750 at 110 psi.
Below are the specs for both wheels:
Part Number
Size
Style
Finish
Bolt Circle Inches
Bolt Hole Dia. Inches
Bolt Hole Nut Seat
Hub Bore Dia. Inches
Backspace Inches
Offset-SRW or Half Dual Space-DRW Inches
Max. Wheel Load Pounds
Max. Cold Inflation PSI
167031
16x7J
LTS 5
Polish
8x6.5
0.62
60 degree conical
5.16
4.29
0.25
3415
95
167041
16x7J
Classic 8
Polish
8x6.5
0.62
60 degree conical
5.16
4.29
0.25
3750
110
Each wheel offers a different appearance (5-spoke or 8-hole) and load rating (3414@95 or 3750@110) to meet your specific needs.  I hope this helps.
Thanks for the inquiry.
-    Brian Thomas
 Marketing Communications
