| Hello,We have a Trail-et New Yorker that we are having problems with the inside lights not working. Does anyone have a wiring diagram that they could post or send me? We are getting full 12V to the light and the bulbs are good - but no light! AUG! Help anyone?Laurie |
  Location: Zionsville, Indiana | First, I assume that you are sure the hot wire in your vehicle plug is working. Trail-et puts a fuse box in the front of the trailer. All the wiring goes thru the fuse box Check the fuses. |
    Location: Lockport, Illinois | If you have 12 v to the light and the bulb is good, then it is your ground. |
| There is a box next to the 12V battery in the dressing room, but no fuses located there. Just wires. |
| any suggestions on how to check the ground? |
