       Location: western PA | You can use the same mats as utilized for the flooring and attach them with sheet metal screws. They also make a lighter, padded foam type of matting which can be used. However, it's more expensive and not as durable. Many owners of stock trailers line the interiors with pressure treated plywood. It's durable, lasts a long while and is inexpensive to install. Gard |
