 Location: elkhart indiana | I have done a couple of trailers different ways it depends on wether or not you are wanting a fold down sofa OR A dinett, sofas come in different lengths usualy between 60" & 70" and usualy between26" and 32" wide. if you are going to use a fold down sofa you also have consider for a couple of inches of clearace from the back so you will be able to fold it down, be sure to check befor you bolt it or it will get stuck down. If you are putting in a dinett I have made them 2' wide to 3 1/2' depending on how wide the trailer is I am instaling it in. I have a picture of one trailer on this sight with a 2' dinett it is on a trailer I did, it also has a 60" bench for storage, it is in indiana they called it a chipper but it is a corn pro, you may look at them to get some ideals, also if you look at different flore plans from other manufactures they will have their dementions right on th floor plan, |
