want to convert livestock trailer to enclosed
bukmstr
Reg. Jan 2009
Posted 2009-01-16 12:06 PM (#97623)
Subject: want to convert livestock trailer to enclosed
wondering if there is a kit or something to convert my 16ft titan stock trailer into an enclosed trailer by purchasing material to cover slots in sides. I'm sure I seen this somewhere before but can't find it anywhere on the net. thanks
Posted 2009-01-16 12:38 PM (#97625 - in reply to #97623)
Subject: RE: want to convert livestock trailer to enclosed
I enclosed the slats on a Cornpro, by cutting and fitting individual Lexan window panels between the studs. Some manufacturers have a track set up wherein you can insert a single long strip. Check with your trailer's manufacturer to see what he has available.
trguy4820
Reg. Jul 2008
Posted 2009-01-16 1:13 PM (#97626 - in reply to #97623)
The aluminum track for plexiglass inserts is called H channel or F channel & is available from Statewide Aluminum in 16-20' lengths. Install the track inside or outside depending on your trailer configuration and then you can slide plex inserts (Lexan) into the tracks and seal the sides of the trailer.
