| my frig in my trailer will work with electric but will not work on propane. Does anyone know what this might be? Also I had a handle break on me that opens and closes the drop down windows can I get that fixed easy? Thanks |
    Location: Lockport, Illinois | Years ago my propane refrig wouldn't work, I had a clogged orfice. It worked great after I cleaned the orfice. |
      Location: Rocky Mount N.C. | racr1971.... What make trailer you got? You may have to see your dealer or go straight to the mfg. to get the trailer window latch... Or, maybe these folks may be of some help.... http://www.statewidealum.com/livestock-trailers-statewide-alum.htm So far as the fridge... Is the the gas on, pilot lit, burner area free of spider webs, rust and debris, etc.?? Search over there at the RV.Net site, good info on LQ stuff!! http://www.rv.net/forum/
Edited by retento 2009-01-12 6:30 AM
       Location: western PA | A few questions; do your other gas appliances work? Do you have a good gas supply in your tanks? Is your valve on? Do you have gas at your stove's burners, and have you tried to use them to bleed any air in the lines? Has the refig been working and just stop, or have you noticed an increasingly poor performance? Check your gas supply and if it's ok, as others have stated, check the gas source at the burner assembly for dirt and bugs. Gard |
| the frid worked when I bought the trailer. It is a 2002 platinum. All other appliances are electric hook up. the frig is the only thing uses propane. How do I clean the orfice? Thanks for help |
