 | Originally written by Brown cow on 2008-11-02 4:35 PM
 We have a trailer with LQ and while at the American Royal at night the temp got down to 28 we had condensation on the edge of the metal strip around the roof inside. Is this normal when it gets that cold on a  aluminum trailer? or does it need to be better insulated?
 Any time condensation forms, it is because the warm, moist, inside air is in direct contact with a cool surface. The area where condensation is forming has inadequate insulation allowing the heat transfer. Aluminum will conduct heat or cold faster than steel, but both metals will end up causing the same affect, if not properly insulated. Adding additional materials usually will help. Gard |
