How much can I pull?
Slidinspots
Posted 2008-09-30 12:26 AM (#92332)
Subject: How much can I pull?
I have a 2002 Dodge 3/4t diesel, 6speed - ok that is the sum total of my knowledge of trucks. Oh wait GVWR is 8800lb. I am pulling a 2000 Sundowner 3H, 8'LQ with a GVWR 15210.
So my question is it OK to use my truck to pull a similar trailer only 4H, totally loaded - 4horses, hay, 4 people and stuff, etc?
Posted 2008-09-30 8:45 AM (#92338 - in reply to #92332)
Subject: RE: How much can I pull?
I think you are over limit with your current 3 horse trailer.  Most 3/4 ton trucks are rated for about 13,000lbs towing.
Looking at Edmunds for the 2008 specs it shows 13,350 for towing max for the shortbed quad cab.
You need to check your owners manual and see what your truck is rated at.  Also look at the sticker on the door that shows you max weight per axle and take your truck/trailer and drive across a certified scale. To see if you have maxed out your tires or axle.
trailers21
Reg. Dec 2004
Posted 2008-09-30 9:43 AM (#92342 - in reply to #92332)
The GVWR is what the axles are rated for loaded. That isn't the weight of the trailer or truck. The pay load for the trailer would be the actual weight of the trailer minus the GVWR. So, if the actual weight of your trailer would be say 9500#, the pay load would be 5710#. The tongue weight on your truck is what you need to be concerned with. The specs on your truck will tell you what your pay load capacity is. You won't be putting the total weight of the trailer on your truck, just the tongue weight of the trailer. Your trailer size sounds reasonable for a 3/4 ton to tow, but you will have to know the actual weight of the trailer and the tongue weight to be sure.
Slidinspots
Posted 2008-09-30 11:05 AM (#92347 - in reply to #92342)
OK so if I do overload the truck, what are the consequences? Is it safety or truck wear [what could fail]? I've got someone who wants me to pull a 4H, full LQ with 4 horses, 4 people and everything associated cross country. I am being told that my truck can pull it but I am worried about what could go wrong or possible damage to my truck.
Posted 2008-09-30 11:33 AM (#92351 - in reply to #92332)
Rear axle, u joints, rear suspension, transmission.........all things you don't want to fail when you're on the road
windy
Reg. Oct 2004
Posted 2008-09-30 11:42 AM (#92353 - in reply to #92347)
Originally written by Slidinspots on 2008-09-30 11:05 AM
My main concerns for a one time cross country trip with a 3/4 ton truck and trailer that size would be more safety related. My big concerns would be single rear tires and how much weight they are rated for vs the actual weight they are carrying. As has been said before, heat is your tires enemy, and an extended trip with several hours at a time of driving at highway speeds can cause more heat build up in the tire, especially in an overloaded condition. The other concern would be stopping power(distance). I'm not saying I wouldn't do this, just that if I did, those would be my main concerns. I would address both of those concerns if I did this by lowering my driving speed. I'd pay very close attention to my tires and tire air pressure as well.The other thing I would do is to drive very defensively in order to address the reduced stopping ability.
Again, I'm not saying I would or wouldn't do this, because until I looked at your particular truck, trailer, tires, and what your plan is, I don't know. I also don't know your driving habits and experience. But if I were looking at doing this, these are some of my concerns and what I would try to do.
Slidinspots
Posted 2008-09-30 1:09 PM (#92361 - in reply to #92351)
Thanks Gard, that is what I was looking for!
Slidinspots
Posted 2008-09-30 1:10 PM (#92362 - in reply to #92353)
Thanks Windy!
gabz
Posted 2008-09-30 4:59 PM (#92373 - in reply to #92347)
1000100100100252525
I haven't read everything here...  Don't do it.
My friend blew up her 2004? Dodge 3/4 ton hauling a 3H alum trailer with 8' shortwall hauling 3 horses on a regular basis. The last trip that truck made was coming back from Tennesee.
If you're going cross-country - you're gonna have even bigger hills. You're going to have to haul hay and water. 4 people = 1000 pounds (their weight + clothing, bedding, etc.)  4 horses = 4800 pounds. Water is 8.64 pounds per gallon and you need 10 gallons a day, per horse. Plus everything that gets dumped into the waste tanks by the humans.
Hay at 60 pounds per bale. 1/2 bale per horse, per day. Taking any grain for the horses? 4 pounds per horse per day? or more?
You need to add all of this up. 20% of the trailer weight will be on the truck + passengers + fuel and anything else you put in the bed of the truck. That's essentially your "payload". Your GVWR minus the weight of the truck gives you your allowed payload.
Who is telling you that your truck can pull it?
Slidinspots
Posted 2008-09-30 5:25 PM (#92375 - in reply to #92373)
Thanks for the example! Telling me it is OK - one person who wants his horse hauled, another who I already promised a ride to. People are desperate to save fuel dollars. I told them that I could be stuck with possible expensive damage to my truck at a later date. They said my truck was HD so should be able to do it, won't hurt it, etc...
Posted 2008-09-30 6:52 PM (#92378 - in reply to #92332)
Gabz nailed it exactly. Don't do it. The people who are telling you to do so, aren't either knowledgeable or your friends.
Posted 2008-09-30 7:25 PM (#92379 - in reply to #92375)
Originally written by Slidinspots on 2008-09-30 7:25 PM
Slidinspots.. Let's think this through a bit.  Your truck is rated to 8800 pounds total.  So... 4400 pounds per axle is what Dodge designed the axles & tires to support.
Your present trailer is rated to 15210 pounds.  That means fully loaded.  As a rough estimate 20% of the total trailer is on the truck hitch ... so 15210 x 20% = 3042 pounds on the hitch.
4400 - 3042 leaves 1358 pounds ... but wait the truck weighs something... less on the back ... let's say 1000 pounds now, you have 358 pounds.  But wait again.  the hitch weighs 150 pounds (my B+W did)  you're now left with 208 pounds.  That's two svelte girlfriends and their horses riding with you in your present trailer.
Hitch to a 4 horse trailer with LQ and two guys and their horses ... Your truck is overloaded...
There is always some margin of overload designed into trucks.  It's your call how much margin you want to use and spend in repairs.
Those "desperate" riders won't be faced with the repair bill, you will
daisycake123
Posted 2008-09-30 7:48 PM (#92381 - in reply to #92332)
You should use a heavier ply tire so you dont overload your tires.
Slidinspots
Posted 2008-09-30 9:39 PM (#92388 - in reply to #92379)
"Those "desperate" riders won't be faced with the repair bill, you will"
Exactly! Thanks everyone for spelling it out. The 4th horse has found a more expensive ride now.
ponytammy
Posted 2008-09-30 10:20 PM (#92389 - in reply to #92332)
500100100252525
Just curious what truck is currently pulling the 4h- 8Ft Shortall? And why they aren't pulling it and asking you to go along instead.
Slidinspots
Posted 2008-09-30 10:34 PM (#92392 - in reply to #92389)
"Just curious what truck is currently pulling the 4h- 8Ft Shortall? And why they aren't pulling it and asking you to go along instead."
The couple I know of are being pulled by 1ton dually, except one my friend has, she uses 3/4T but it is used to haul one horse and carriage and Ford told her to not load it up with horses. It was suggested "we" borrow a 4h with LQ to use for the trip but still use my truck. No, I don't have the cajones to ask to use one of my friends trailer but was afraid they might come up with one as it sounded like they had one to borrow.
3horse
Posted 2008-10-02 8:57 AM (#92443 - in reply to #92332)
I am SO glad you asked the question about pulling!  I'm sitting here with the spec's from the panel on the door frame of my F-150, 4x4 (w/ off road and towing package).  It appears my rear axle is rated to 3550 GAWR.  I'm moving up from a steel stock to an aluminum horse trailer and want to know my limits.  My understanding from the discussion, I should take off the weight of the truck (about 1000 lbs) which leaves me about 2500 lbs I can put on the rear axle.  Also, of the trailers I'm looking at, up to one fourth of the weight of the trailer will be sitting on the rear axle, so I can consider up to 10,000 lb gross weight.  Am I in the ball park?
As an asside, I've been watching for trailers on Craigslist and have asked trailer weights of the one's I'm interested in.  It's amazing how many times I get "I don't know, I need to look it up".
Thanks
chadsalt
Posted 2008-10-02 11:38 AM (#92451 - in reply to #92443)
1000100100100100
Originally written by 3horse on 2008-10-02 9:57 AM
Thanks
You're in the ball park, but the ass end of an F150 weighs closer to/probably a little over 2000#.  What year is it?  This site can help if its newer than 02.
https://www.fleet.ford.com/showroom/rv_trailer_towing/default.asp
3horse
Posted 2008-10-02 7:43 PM (#92477 - in reply to #92332)
I just visited the Ford site.  I have a 2001.  Can I assume the 2002 specs would work?  Fifth wheel?  Once again I'm seeing reference to axle ratio.  Where do I locate that?
One more question. . .under the engine designation next to 4.4, 4.6, 5.4. . . is "sefi".?????
Appreciate your answers.
Posted 2008-10-02 8:39 PM (#92483 - in reply to #92477)
Originally written by 3horse on 2008-10-02 9:43 PM
Ford uses a Sequential Electronic Fuel Injection system to get fuel to each cylinder. What this means is that the SEFI engines inject fuel, one cylinder at a time for better control. SEFI is the better system than the old throttle body injection system, that injected fuel into the manifold.
Posted 2008-10-02 9:00 PM (#92484 - in reply to #92443)
Originally written by 3horse on 2008-10-02 10:57 AM
Thanks
Whoa !! For a 2001 F150 the max legal load is 1542 pounds. (701 Kg)
From here >> http://www.internetautoguide.com/car-specifications/09-int/2001/ford/f-150/index.html
Are you considering a GN trailer?? 1500 pounds isn't much for a GN trailer.
The max trailer weight you may tow is the Combined Gross Vehicle Weight Rating minus 4044 pounds.  The CGVWR is in your manual.  The 4044 pounds is from the above site as curb weight (pounds = Kg x 2.2)  Remember passengers, optional equipment, and stuff in the bed count too.
chadsalt
Posted 2008-10-03 6:55 AM (#92498 - in reply to #92484)
1000100100100100
Originally written by hosspuller on 2008-10-02 10:00 PM
I'm not sure what country that site is for (everything is metric?), but in the US the legal payload is generally determined from the axle ratings, not the GVWR.  Motor vehicle manufacturers can make recommendations, not laws.  This means to find out what the pickups payload is requires a trip to the scales compared to guessing.
My Dmax states a payload of ~2600# on the door, compared to the GVWR-curb weight formula of ~2000#.......compared to the ACTUAL legal payload of ~3000# it is register/tagged for here in SC.
I do not intend to get in a lengthily discussion here, this fact has been beat to death all over the web.  A quick read over any of the hotshot forums or a simple call to an individuals respective states 'diesel cop' will likely explain this concept to those unfamiliar.
chadsalt
Posted 2008-10-03 7:23 AM (#92499 - in reply to #92332)
1000100100100100
3horse,
The 3550 you listed sounded funny to me, so I took a look around.  Seems like thats the front axle.  Take a look here,
http://www.ford-trucks.com/specs/2001_f150_1.html
3horse
Posted 2008-10-03 8:41 AM (#92502 - in reply to #92332)
The tag on the door frame says. . . (I didn't mention before, this is an extended cab, along with full size bed, the 4x4, tow and off road pkg)
GVWR 6500LB/2948KG
REAR GAWR 3550LB
So I guess my quandery . . ./  concern. . ./ let me say this back to you, my limit is 1500 load on the rear axle, hence the trailer should not weight over (considering 20-25% of loaded weight of the trailer on the axle) 6000-7500.  The most weight I've ever pulled has been 5500, the truck wasn't straining, overdrive was off, and I didn't have the brake controller attached at the time.
Let me say this is the most information I've gotten in a very long time.  Glad I found this site.  Thanks you for your advice.
3horse
Posted 2008-10-03 9:04 AM (#92504 - in reply to #92332)
Just finished going through the 15 pages of Ford specs.  On the 14th page under "Payload and Towing Weights"  it says max trailer tow is 8000 lbs.  An aluminum GN EBY I recently looked at, a 3 horse slant, 4' short wall, unloaded is 5500 lbs.  Gross weight loaded is 9800 lbs.  I have no plans of pulling three horses.  Mostly one at a time and sometimes two (when my spouse rides too).  I guess my question has been answered.  It's doable.  Woooo.
headhunter
Reg. Oct 2004
Posted 2008-10-03 4:58 PM (#92540 - in reply to #92504)
50010010025
3 Horse,
The tow weight is different than the 5th wheel weight.  Towing an 8000 lb trailer puts +/- 800 lbs on your bumper hitch, and therefore onto your truck.  Towing an 8000 lb 5th wheel/gooseneck puts +/- 2000 lbs directly over your rear axle and onto your truck.
There is a difference between towing capacities for bumper pull and 5th wheel/gooseneck trailers.
3horse
Posted 2008-10-04 1:16 PM (#92576 - in reply to #92332)
Then I guess I'm back to the drawing board.  I'm going to go visit a Ford dealer and see what they say.  Thanks for your info.
Posted 2008-10-05 11:05 AM (#92600 - in reply to #92332)
here are several things to consider in what a truck will tow.  How much power the truck has, the ability to pass that power through the power train to the tires, the ability to stop the load when braking, Shocks, springs and other suspension componets.  These all are factored together to calculate the trailer weight you truck will tow. In your case 8000lbs. This is usually calculated by taking the GCVW ( the weight of both the truck and trailer) and subtracting the weight of the truck to leave the max towable weight.  Most truck manufactures advertise this number based on their lighter trucks, since they have a higher tow weight.  A regular cab, Short Bed,2 wheel drive truck weighs less than a Crew Cab, Long Bed 4x4. So be carefull which spec sheet you look at. Make sure it's the specs for your truck.
Then you need to look at where the weight of towing is carried. As stated a gooseneck of 8000lbs will put 20%-30% of it's weight on the truck (depending on trailer design)  25% of 8000lbs puts 2000lbs on your trucks rear axle. I think you said in a previous post your truck is rated somewhere in the 1500-1600lb range for  payload. So even though you are within the rating of what your truck is rated to tow (8000lbs),  you are over the payload limit of what weight you can sit on top of the rear axle (1500 lbs)
If you through a few bales of hay in the bed, have you two roping buddies jump up in the cab with you, The truck is over weight.
Terri
Posted 2008-10-05 5:56 PM (#92617 - in reply to #92576)
200050010010010025
You'll be lucky if you can find anyone at the dealer that knows anything about towing.  Look in your owners manual under towing and see if there is a 5th wheel weight in there, there is in my dodge and the difference between the two types is quite a bit.
HOUSE
Reg. Oct 2008
Posted 2008-10-10 10:18 AM (#92870 - in reply to #92332)
I would not have too much concern assuming that all of your tires are not over weight.... ie go weight you loaded truck and trailer and assuming it is a gooseneck.
too many trailers just do not have the axles/tires to handle the weight that a trailer can haul.... jmho
I personally have hauled horses from calgary to california with way more weight than that... i was weighed when i came back into the us and i had to offload 2 bales of hay so that i could be under 26,000. mind you i was in a ford 3/4 ton truck, might be a better truck :) but i was also hauling 5 clydesdale horses so you should be ok.
