Posted 2008-09-14 9:17 PM (#91488) Subject: cleaning white aluminum
I recently purchased an aluminum bumper pull; the area of the nose and the tack room is white aluminum and has some sort of streaks on it and the remainder of the trailer is a mill finish. I was wanting to clean the white part but don't know what is best to use to remove the streaks. It was parked and not used much for the past two years. I used car wash products, but it didn't remove the streaks just the dirt. Any advice will be appreciated.
Posted 2008-09-14 9:24 PM (#91489 - in reply to #91488) Subject: RE: cleaning white aluminum
In our parts store we sellsome stuff call B-52 and the company said you could use it on the white skin on the back of the bottle tells you how to dilute it, I used it today and it works and it is not expensive and you can use it on other things.
Posted 2008-09-15 8:03 PM (#91537 - in reply to #91488) Subject: RE: cleaning white aluminum
Use the white wall tire cleaner from wal mart.......I use it diluted like on the tires.. .......wax the white areas after wards..........You will not believe the difference.....Paul
Posted 2008-09-23 6:22 PM (#91998 - in reply to #91488) Subject: RE: cleaning white aluminum
We use RV Cleaner on our trailers and it has worked great. You can find at Camping World or any RV parts store. I've also heard the Mr. Clean magic whipes work wonders as well.
