Last time we were at a campground my husband blew the fuses on my ciggarette lighter and power outlet. The power went out when he was in the middle of making margaritas so he pulled out the small power inverter, plugged it into the ciggarette lighter and blew the fuse. Then in his desperation to have that margarita he plugged it into the power outlet and blew that fuse. I replaced both fuses, but the power outlet is still not working. Any ideas? I've tried to get up under the dash and see if there is a inline fuse somewhere but I'll be darned if I can even SEE up under the dash, much less find a wire. I don't see how to access anything. I've checked the fuse box under the hood and under the dash and switched the fuse out with a new fuse just in case it was blown with out looking it. I also checked every fuse in both boxes just in case one was blown and someway connected to the power outlet. HELP. |
