Truck fuse question
spotter
Posted 2008-09-04 8:27 PM (#90981)
Subject: Truck fuse question
Just picked up my "new" used truck today (matches my horse trailer nicely)....'06 GMC 1/2 ton 4x4, and while I was sitting in my driveway with the radio on, reading the manual and playing with everything to figure it out, I managed to blow the fuse for the power seats. I've figured out that the fuse is in the center fuse box under the dash, and best I can see, it's more of a connection box...black up under the dash on the left side of the steering column...but I can't figure out how to access it/get the cover off. Anybody able to give me some help? Thanks!
Posted 2008-09-05 8:05 AM (#91008 - in reply to #90981)
Subject: RE: Truck fuse question
1000500100100100252525
you could ask the parts department at a dealer most are very helpful  with small jobs like that I did ask them how to get the radio out with out taken the dash board apart
Posted 2008-09-05 8:15 AM (#91010 - in reply to #90981)
spotter... On my 2001, there's a access door on the end of the dash next to the drivers door. With the drivers door open, you'll see the access door, it just pops off, a fuse puller is attached to the back side of the door..... That is if the 06's are simular to the 01's. When all else fails, check your owners manual.
Tresvolte
Reg. Feb 2008
Posted 2008-09-05 8:39 AM (#91015 - in reply to #90981)
The 06's are the same way as your 01 Retento. Open the door and you will see the fuse panel cover on the end of the dash.
Edited by Tresvolte 2008-09-05 8:40 AM
spotter
Posted 2008-09-05 11:23 AM (#91029 - in reply to #90981)
Thanks everybody....I finally got it. The fuse I needed wasn't in the side panel by the driver's door...and it turns out is wasn't in the under the dash box either....it was in the engine compartment fuse box.
