Another Water tank question..
lilcashseeker
Posted 2008-08-27 7:01 PM (#90559)
Subject: Another Water tank question..
Hurricane Survivor
Ok.. So how do you fill it? In the area that I usually hook the water hose up to there is a nother nosle thing that says not presured water.. isn't that where you fill it? and do you need a special hook up to fill it..
Dang it's a bit late to ask... but ...
I can go take photos if needed.
greyhorse
Reg. Nov 2005
Posted 2008-08-27 7:09 PM (#90560 - in reply to #90559)
Subject: RE: Another Water tank question..
Yep, that's where you fill it.... you just stick the hose in and fill it until it's full, water will start coming out the breather. The other one where you can screw the hose in is if you are connected to a water supply like at a campground or at home, this one bypasses your pump and just uses the pressure from the water supply.
lilcashseeker
Posted 2008-08-27 7:17 PM (#90561 - in reply to #90559)
Hurricane Survivor
Do you have to have a hose w/out a nosle on it? or is there a rubber flap that has to open for the water to go thru? it didn't seem to let the water in when I tried to hold the hose against it.
Posted 2008-08-27 7:27 PM (#90562 - in reply to #90559)
Unscrew the white cap.
Place the end of the hose in the opening and let it run.  Depending on your trailer and your home water pressure, you may have to turn down the pressure and just let it run in at a moderate flow.
When it's full, water will back flow out of the opening and out the breather hole.
lilcashseeker
Posted 2008-08-27 9:21 PM (#90570 - in reply to #90559)
Hurricane Survivor
yep.. got the water in .. now to get the pump to make the water come out.. got dark on me so this is something I'll have to work on again when I get home from work tomorrow....
