| Approx. 2 years after I had my LQ (my husband did my trailer), my water pump will not shut off the way it is suppose to, it sounds like a machine gun going off right before it shuts off. We have changed the pressure switch then we thought the problem was the toilet, but it wasn't that either. Does anyone have any ideas on how to fix this problem? |
  Location: Kansas | Is it still on warranty? send it back. Did you by chance have the pump running and it ran out of water? That can be a major problem. |
       Location: western PA | Some pumps have an inlet filter screen. Does yours? is is partially blocked? Gard |
  Location: Kansas | Ithe the best solution would be to call the manufacter and talk to thier service dept. what kind of pump is it? |
| It is a Flojet. |
  Location: Kansas | here is the contact us form http://www.flojet.com/scripts/enquiry.htm
DEPCO PUMP 2145 CALUMET ST CLEARWATER FL 33758 USA Tel: 800-446-1656 Web Site: http://www.depcopump.com
| Offers these ranges: • Agricultural • Bottled Water • Industrial • Marine • RV |
| I would use this infomation to get help on diagnoising the problem with it |
   Location: Henderson, TN 38340 | Does your trailer have a pressure riser, or a tank to accumulate air pressure? It may be that your riser has become water logged. If you turn your water on very slightly, does the pump sound the same? I had to add a pressure tank to my system to slow the pump cycling on and off. Turfa |
