Middle part of Bumper Pull
Frankie001%
Reg. Feb 2005
Posted 2008-08-21 9:44 AM (#90105)
Subject: Middle part of Bumper Pull
I need help with this since I have never done this before.  How do you remove the middle part on a bumper pull?  It is a two horse and a older model.  Any advice would help.  I do not have the model number.  Thank you in advance.
Posted 2008-08-21 10:05 AM (#90107 - in reply to #90105)
Subject: RE: Middle part of Bumper Pull
You want to remove the divider of a two horse straight load BP trailer ??
Usually there are pins that hold the divider at the head end and upper tailer end.  One trailer I helped with, had a tab at the tail end that fit into the floor.  The whole divider had to move backwards a bit to disengage the tab.  A name or pictures of your trailer would surely help get someone who is familar with your trailer to post.
You can easily post pictures into an album on this site.
Frankie001%
Reg. Feb 2005
Posted 2008-08-21 11:11 AM (#90111 - in reply to #90105)
Thank you Hosspuller for your information.  I will try to get the model and pictures.  Now to get out there after work and get it done.
gabz
Posted 2008-08-21 4:28 PM (#90136 - in reply to #90111)
1000100100100252525
Older BP 2H trailers may not have completely removeable dividers.  2 of mine, the body section came out, but not the divider between the heads. And, the post at the back stayed put too.
