Slide won't go out
Latts55
Reg. Feb 2014
Posted
2018-02-19 5:53 PM (#171307)
Subject:
Slide won't go out
any input why it won't slide out fuses and battery are good?
cajunmuleman
Reg. Oct 2011
Posted
2018-02-20 5:05 AM (#171308 - in reply to #171307)
Subject:
RE: Slide won't go out
Is the switch good? use volt/ohm meter to check. Is it hydraulic ?
Latts55
Reg. Feb 2014
Posted
2018-02-20 6:25 AM (#171309 - in reply to #171307)
Subject:
It is electric, and the switch seem good
akinstrailers
Reg. Apr 2009
Posted
2018-02-20 11:30 AM (#171310 - in reply to #171307)
Subject:
Did you check the ground on the motor.
Posted
2018-02-20 11:26 PM (#171313 - in reply to #171307)
Subject:
Latts55 - 2018-02-19 8:53 PM
Does it make noise when pushing button?
When you say the battery is good...did you do a load test on the battery?
Also, will your slide operate MANUALLY?
Edited by PaulChristenson 2018-02-20 11:31 PM
Latts55
Reg. Feb 2014
Posted
2018-02-21 6:06 AM (#171314 - in reply to #171307)
Subject:
Makes no noise almost like it's got no power. Tested the switch and there is power to the switch
horsey1
Reg. Dec 2004
Posted
2018-02-21 11:02 AM (#171316 - in reply to #171307)
Subject:
Assume you checked to see if power coming out of switch. If it is, I'd next check at the motor to see if power is there with the switch activated.
Posted
2018-02-21 3:02 PM (#171319 - in reply to #171314)
Subject:
Latts55 - 2018-02-21 9:06 AM
Your slide unit doesn't have
fuse on a PC board next to each slide motor
itself does it?
Edited by PaulChristenson 2018-02-21 3:05 PM
DLR
Reg. Jul 2004
Posted
2018-02-22 5:55 AM (#171323 - in reply to #171307)
Subject:
It may help if we knew what brand of trailer and conversion. You stated on 1st post that fuses were good - which ones did you check?
Latts55
Reg. Feb 2014
Posted
2018-02-22 6:35 AM (#171324 - in reply to #171307)
Subject:
It's a bison, and I check the inline fuse by the switch.
Latts55
Reg. Feb 2014
Posted
2018-02-22 1:36 PM (#171327 - in reply to #171307)
Subject:
It was a bad wire tks for all your help.
Posted
2018-02-24 12:52 AM (#171332 - in reply to #171327)
Subject:
Latts55 - 2018-02-22 4:36 PM
Thanks for the feedback...hopefully you'll be trouble-free for the upcoming season...
