Location: Tavares Florida | Has anyone ever removed the stall dividers from a Hart slant load trailer? If so how is it accomplished? Thanks Keng |
![100](https://horsetrailerworld.com/forum/images/decorations/multiple/100.gif) Location: Calgary, Canada | I have removed the dividers on our 2006 Hart 3H gooseneck. Was pretty straight forward ... I recall the stud stall had 3 pins ... one pin includes a spring ... just pounded the three pins straight up with a hammer and drift punch (you could use a hammer and nail also). Have someone hold the stall while you do this, the stud stall was quite heavy (over 100 lbs). The regular divider had two pins I recall ... one pin includes a spring ... again drift the pins straight up and out. Regards, 3CW |
![100](https://horsetrailerworld.com/forum/images/decorations/multiple/100.gif) Location: Calgary, Canada | I should also add to drift the pin with the spring out first. This way the stall will still be pinned and you are not fighting the spring. Regards,
3CW |
